rear speakers rattle... brand new car
Old Feb 16, 2007 | 01:22 AM
  #31
psedog's Avatar
Back in SD**
Originally Posted by BadBoy06
Its been 5 months, I would hope he has this issue resolved by now
Good point. I did a search on rattles, didn't even think to look at dates, stupid me.
Old Feb 16, 2007 | 10:52 AM
  #32
kidtronix's Avatar
Optional
My rear seatback's latch rattles, and there's no adjustment for the striker or anything. I thought it was the parcel shelf or a speaker.
I had to fashion a foam block with a slice in the center (not a hole). I slipped it over the striker loop and it fits tight. Now when the seatback latches, the foam piece provides enough spacing to eliminate the rattle without impeding the effectiveness of the latch itself.
If you do this, use the type of foam that a lot of electronic devices come in, not true styrofoam. The anti-static stuff that electronics come in wont squeak when it rubs against plastic like traditional styro will
Old Feb 16, 2007 | 07:06 PM
  #33
patrickwong's Avatar
Holy crap, i think that's what is causing my ratttling too. When i put down the rear seat, i don't hear it anymore. I really need to find a way to fix it.
Old Feb 16, 2007 | 07:09 PM
  #34
GWord256's Avatar
Sorry if someone already posted it, I only read the first page but here's my tip.
Turn off the radio and listen to the exhaust. It doesn't have commericals!
Old Sep 5, 2007 | 11:37 PM
  #35
Woblin_Goblin's Avatar
Originally Posted by G Thizzle
Had a rattle... i ended up finding out it was the rear part of my headliner that was hitting the back window... so i stuck some dynomat in between the liner and the window and the rattling stopped... that was my problem....
+1 I encountered the same problem and solved it in the same way. Every now and then I need to adjust/reposition the fabric that I jammed between the liner and window.
Old Jun 9, 2008 | 05:55 PM
  #36
ar9080's Avatar
the same thing happened to me-orig G35sdn. i called bose and even though the rear sub was out of warranty they replaced it for free-they said it was a torn voice coil
rezendvous420
May 31, 2020 01:26 PM
mjfenix
Aug 17, 2017 05:49 AM
