Set Up opinion! Help
Old Sep 24, 2006 | 08:36 AM
G35-G35's Avatar
I need to know if this set up will work and do anything? i have a 06 at coupe. i wanted to put a plenum space and intake. i was thinking of going motordyne 5/16" and a nismo or jwt or stillen intake. help any advice on the spacer??????? opinions needed thanks
Old Sep 24, 2006 | 09:19 AM
WhiteonWheat's Avatar
Question
I hope I'm not highjacking, but I have a question about the spacer options as well. Maybe this will add to your question G35-G35...
What is the MAIN difference we should expect between the 5/16" and 1/2"?
What I do know:
* 5/16" allows you to keep the OEM plenum cover.
* 1/2" does not ^
What about HP/Torque differences?
I seem to hear/see more members go with the 5/16", is this b/c of the OEM cover or performance?
Is the 1/2" *TOO MUCH* space? Decrease in HP?
Thanks,
-WoW
Old Sep 24, 2006 | 10:06 AM
G35-G35's Avatar
thats ok that is a good question. I hope to hear responses
Old Sep 24, 2006 | 10:14 AM
Sumlime311's Avatar
no the 1/2 is not to much space and you do not lose any HP. with the 5/16 spacer you get your HP a little earlyer than you do with the 1/2 spacer. But when the 1/2 space kicks in, you get more HP with it than you do the 5/16.
Hope this clears some things up.
Old Sep 24, 2006 | 10:17 AM
Sumlime311's Avatar
And i think the setup you are wanting will do just fine for you. You will love the sound it gives you and the push back in your seat the spacer will give you (either spacer). I went with the 1/2 MD spacer and the JWT popcharger for my intake system. I Love It!!!
Old Sep 24, 2006 | 10:26 AM
G35-G35's Avatar
ok so then this 5/16 spacer will work well and will fit my 06 auto tranny? if so then here comes ups in about a week
Old Sep 24, 2006 | 10:58 AM
Sumlime311's Avatar
yes it will fit perfectly for your 06 5AT and you will love it!
Old Sep 24, 2006 | 11:45 AM
Calvin's Avatar
Overglorified Altima
5/16"
allows you to keep engine cover
gains throughout the power band
1/2"
doesnt allow the use of the engine cover
slightly less power in the low end but youll gain it back and a little more up top
Old Sep 24, 2006 | 11:47 AM
Calvin's Avatar
i have an 06 5at and i have the 5/16" with iso thermal md spacer
works fine for me
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
migurus
Sep 5, 2015 09:39 PM
Machine Head
Sep 4, 2015 07:22 PM
TheBay
Sep 3, 2015 03:27 PM
