Help please-wheel fitment
Old Oct 1, 2006 | 03:31 PM
1BADV6's Avatar
I tried posting for help in the CORRECT forum a while ago, and got 0 responses in 2 threads so I am posting this here to actually get an answer.
I'm trying to figure out how this wheel will fit:
FRONT SIZE: 19x9.5"; Bolt Pattern: 5:114.3mm; offset: +30 mm;
REAR SIZE: 19X10.5"; Bolt Pattern: 5:114.3mm; offset: +28 mm;
I have a coupe with Brembos. Now I want to get the largest sidewall I can on the tires to keep those wheels protected. I have no intention of slamming it, but may want to go H-techs if I don't like the fenderwell gap after installing.
How are these tire sizes in relation to those wheels:
Front 245/35/19
Rear 275/30/19
I don't really want to get the stretched look either, so if I need to go wider then that's fine.
I really want to know if the wheels will fit good and then what tires would go best. I think those offsets should produce about a 3 and something inch lip in the back...right?
Thanks in advance for any and all help/advice!
Old Oct 1, 2006 | 03:35 PM
BOCABLACKG35's Avatar
To be honest with you, forget about 19" wheels. I had both 19" and 20" and not only is the ride better with my 20" wheels, but, the look is a 100x better. 19" in my opinion is way to small, especially without a drop, but nonetheless, they look to small. Go for 20" and drop the 19". You will thank me later.
Old Oct 1, 2006 | 10:40 PM
1BADV6's Avatar
I appreciate the advice, but most Volks or other light weight wheels that I like are not offered in 20's.
For God's sake people, please answer my question. If a wheel/tire question can't be answered in either of the correct forums or this forum I am seriously going to be PO'ed.
Old Oct 1, 2006 | 10:45 PM
jjyellow's Avatar
You should be fine with that setup. shouldn't rub with a drop either. I Have a similar set up with no problems
Old Oct 1, 2006 | 10:46 PM
jjyellow's Avatar
Volks do come in 20's just not all of them. If you want a used set of maido gr-5 in 20s i have a set
Old Oct 1, 2006 | 10:51 PM
siq35's Avatar
go with dpe I just got a full sponsor they can custom cut and they have pretty tight wheels
I went with 20's, 19's look clean but in the world of show an inch can go along way. Plus Dunlop just picked me up on a full ride we went
285/30/20 in the rear and 245/35/20 in the front on the sport maxx
I will post some picks when the rims roll in I am hoping soon, but they are being custom cut and engraved for the car I am building.
Old Oct 1, 2006 | 10:52 PM
johnbigbootie's Avatar
I'm no expert so take this for what it's worth..I have 19 x 10.5" rears with +32 offets, 275/35/19 tires on my rears (Coupe w/Brembos). My rough measurement from the top of the tire to the edge of the fender is about 3/4". So with +28 offset that would push the tire out another 4mm from how mine sits, that *should* work (again, based on my rough measure). As far as clearing your Brembos I think that's typically more of a wheel design rather than an offset issue. If you're looking to get Volks, seem like almost every Volk wheel clears Brembos; you can probably find a Coupe with Brembos on the forum with every Volk wheel to confirm...
I run 19 x 8.5's up front so I'm no help at all with your 9.5" comparison.
1BADV6's Avatar
Right, I know not all of them do but the Challenges for example don't and those are what I really want.
Old Oct 1, 2006 | 11:18 PM
siq35's Avatar
ask them if they are designed to clear big brakes or not when you purchase.
Old Oct 1, 2006 | 11:19 PM
siq35's Avatar
dpe has a sick set of 5 spokes they make for a G
Old Oct 2, 2006 | 10:19 AM
1BADV6's Avatar
TTT for answer on tire size
KruZZe
Feb 27, 2023 05:04 PM
Kelvin Style006
May 23, 2016 03:47 AM
magnetism80
Jan 27, 2016 12:57 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
the93owner
Oct 4, 2015 09:40 AM
