G35 06 Fuel
Old Oct 3, 2006 | 09:08 PM
StoreKeeper's Avatar
Question G35 06 Fuel
Can you run Mid-Grade gas?
Thanks in advance
Bruce/StoreKeeper99Z28 (USN)
Old Oct 3, 2006 | 09:11 PM
Calvin's Avatar
Overglorified Altima
this has been discussed before lol
the salesman at infiniti told me to run the lowest gas and as long as im consistent i will be okay
then i asked the tech guys and they said hell no
its not THAT much more for premium...just stay with 91 octane IMO
Old Oct 3, 2006 | 11:33 PM
filanj's Avatar
salesmen are stupid... they should put the tech guys out on the floor, they would sell more because they actually know what they are talking about
Old Oct 3, 2006 | 11:34 PM
tomcatm's Avatar
Run Shell V-Power 93 Octane and dont look back.
Old Oct 3, 2006 | 11:36 PM
rockd's Avatar
here in mass i can only find 87/89/93... so obviously i go for the 93. It's like 30 cents more, but it's good to know I won't ping or knock. Plus, it's good for the car
Old Oct 3, 2006 | 11:40 PM
MadMatt1144's Avatar
Definitely get the best one available...usually a 91 or 93 octane. The prices here in Illinois have dropped to almost 2.50 for premium so I've been so happy lately.
Old Oct 4, 2006 | 12:36 AM
2006_G_coupe's Avatar
+1 on that..^^
Old Oct 4, 2006 | 12:40 AM
nightrider's Avatar
from the past i have ran mobile 1 synth. I have to have an oil change soon. Thinkin about getting reg oil. Is it ok? cause of price
Old Oct 4, 2006 | 01:05 AM
mark4x4's Avatar
A mechanic told me that once you switch to a synthetic, it's best to stay with it and not to change back to regular oil. I have no reason why although, I was going to ask my regular mechanic his opinion.
Anyone with more knowledge, I'd appreciate any opinions on this. I'm considering switching over to Mobil 1 and I would also like to know if switching back is possible.
Old Oct 4, 2006 | 01:27 AM
jclit's Avatar
Both of these subjects have been discussed throughly, i suggest you do a quick search, and decide for yourself if you want to switch or not.
Old Oct 4, 2006 | 09:56 AM
izmir41500's Avatar
G35driver Addict
Do the math. if you're trying to save money it's not going to save you that much in a year. it's usually 10 cents dfference between 91 and 93. so for a full tank you would save $2. if you fill up every 2 wks then you would save a $52 in a yr.
Old Oct 4, 2006 | 10:12 AM
ericsherbrooke's Avatar
the manuel sugest to put no less than 91, guess what?
I use 91......dosen't really a question for me.
You should use the octane rating specify by the manufacturer, if using a higher/lower octane give you better results you need correct you fire timing in the engine.
Remember, higher octane is not more "explosive" or more "powerfull" it just light up sooner than a lower rating octane.
Old Oct 4, 2006 | 10:24 AM
Ca$hio's Avatar
Nope
Old Oct 4, 2006 | 10:29 AM
TheKnite's Avatar
^ +1 to that. I fill up every week, but the savings are still insignificant.
Old Oct 4, 2006 | 10:35 AM
izmir41500's Avatar
G35driver Addict
higher octane combusts later. lower octane is more susceptible to detonation. meaning higher octane ignites with spark timing and it won't knock as much.
