Horn wont turn off!!! Help!
Old Oct 19, 2006 | 01:12 AM
addisontc's Avatar
Tonight when I got home, I got out of my car and I closed the door. I hit the lock button on the remote as usual and the horn went off and wouldnt turn off. I live in an apartment and this was pretty loud so I frantically unlocked the car, and it proceeded to honk. I turned on the car and the horn quit. So I did it all over again and it did it again. It has been rainging all day so Im hoping something is just wet. So I just hit the lock button with the door open and it locked as usual and I closed the door. No horn.
So has anyone heard of this before? Any information or advise anyone can give me? I did a search and found nothing.
Old Oct 19, 2006 | 01:16 AM
realgone's Avatar
Widdle ya into kindling
i have my remote set so that when the car arms, there is not horn, it is silent. I think you press the lock and unlock simultaneously to choose which option you want. Not sure, but you can verify this by looking in your owners manual. Maybe that will help with your issue.
Old Oct 19, 2006 | 01:22 AM
addisontc's Avatar
Yeah I knew that, but that will only mask the problem.
Old Oct 20, 2006 | 01:12 AM
addisontc's Avatar
well the next morning my battery was dead... I got it jump started, drove it to my home town which took 3 hours, now everything works fine. I also changed my oil and replaced my brake pads today, Hawk HPS that all took another 2 hours. taking that plastic cover off to change the oil is a pain!
Old Nov 16, 2006 | 09:55 PM
gte192t's Avatar
So it rained really hard here in Virginia today. Well, sure enough, when I went from where I work to my company's office, I went to arm my car and the horn did exactly what yours did.
I disconnected the battery this evening, and I'll reconnect it in the morning. I hope it fixes it!
Old Nov 17, 2006 | 12:17 PM
wongdood's Avatar
you don't need to take the plastic cover off to change the oil.. but it is a pain b/c i had to remove it for the sway bar install
Old Nov 17, 2006 | 01:27 PM
ttrank's Avatar
Grocery getter
WTF, two people with this problem. That's odd...
Old Nov 17, 2006 | 02:01 PM
Nismo G's Avatar
HAHAHA thats pretty funny.......There is a way to silent the horn with the remote so it wont honk when you lock the car.
Old Nov 17, 2006 | 05:51 PM
Dubfound's Avatar
My buddy had a Big Red Neck Bronco for the winter (he is into the 70s cars) and anyway everytime he turned the wheel to the right the horn would go off. I guess a wire must have been split. It was funny people in front of him would get so pissed! haha
Old Oct 9, 2008 | 11:46 PM
DRAGMODE's Avatar
sorry to bump an old thread back from the dead, but this just happened to me, and was wondering if anyone has found the problem. It was raining really hard today. Don't know if that has anything to do with it. I was up stairs in my condo and Out of no where, I here my car horn blasting in my garage.....As the OP stated, I freaked out and ran downstairs....It was a long continuous horn. I opened the door, and put the key in the ignition and one turn, and the horn cut off....... WTF?????
Old Dec 11, 2008 | 10:27 AM
eddieb337's Avatar
I had the same problem last night!!! Gte192 did you ever find a resolution to your problem? Wish more would have followed up. Last night it was raining, hit the lock door button and that set the horn off. Tried it 3 times and got the same result. I stopped messing with it as to not **** off my neighbors and this morning when I went to go to work the battery was dead.
Seems like this is becoming more common of a problem. Guess I'm number 4 of this board so there must be many more.
Called the dealer just now and they didn't have any idea.
I bought the car new, 4 years ago, An 04' coupe. I plan on getting a battery today afterwork and replacing it. I hope this remedies the problem. Any feedback from you other guys who have had this happen would be appreciated.
Old Dec 11, 2008 | 11:43 AM
realgone's Avatar
If I had to guess, and I am far from a car expert, it sounds like a battery problem. It sounds like this is happening mainly on 04's, so the cars are 4-5 years old, about the life of a battery, so that may have something to do with it. Mine is an 04 and my battery went dead pretty quick the other day when I was drying my car off and left the radio on, within 5 minutes, if my horn starts causing problems, I will know.
Old Jan 7, 2009 | 11:30 PM
djkace77's Avatar
I am having the same problem, but with a 2003 sedan. I left my car running today and when I walk away the horn went off for no reason. It has been raining hard a lot and snowing all day. I have been trying to trace the problem through the wires, but have no answer. Whenever i try to put a new 15A fuse in there it just blows everytime I try to honk the horn. I am so confused adn pissed because it is annoying...
Old Sep 11, 2011 | 03:15 PM
onthe3rdday's Avatar
04.5 Same problem. Just installed the ambient temp sensor AND went through a cra wash earlier today? ANy resolution???
Old Sep 11, 2011 | 09:16 PM
dukehotty's Avatar
When it rains hard, my car keeps telling me that my trunk is open. It happens every time it rains hard. I hope my horn doesn't do start too!
