Pinging Spark Knock Pre-Ignition
Old Oct 27, 2006 | 12:58 PM
bythabay's Avatar
There are several threads on these issues usually pertaining to rev-up motor G35s (both coupes and sedans). I am starting this thread so that we can get a head count of how many people are actually having this problem so reply only if you have unresolved/unsolved/mysetrious pinging in your rev-up vq35.
1. ByThaBay (05 6mt Sedan, stillen gen 2, pinging from day 1, san francisco, ca)
Sometime later we may need to use this list to petition to have the issue resolved.
Old Oct 27, 2006 | 01:02 PM
Fini's Avatar
1. ByThaBay
2. Fini
Old Oct 27, 2006 | 01:11 PM
zipzow's Avatar
1. ByThaBay
2. Fini
3. zipzow
Old Oct 27, 2006 | 01:24 PM
jeffy1's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
Old Oct 27, 2006 | 01:55 PM
ttrank's Avatar
Grocery getter
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
5. ttrank (only at very high rpm on hot days with Stillen stage 4)
Old Oct 27, 2006 | 02:06 PM
trey.hutcheson's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
6. trey.hutcheson (from the factory) - 32k miles, stillen airbox, ztube, mrev+, test pipes, exhaust - part throttle, heavy throttle, low rpms, WOT, cool, hot
Old Oct 27, 2006 | 02:16 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
7. Foo_G ( on acceleration and in high RPM it is really bad )
Old Oct 27, 2006 | 02:39 PM
absolutg's Avatar
workin...
what are symptoms of pinging?
Old Oct 27, 2006 | 02:40 PM
shaigh's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
8. SHaigh (stock, discovered @6K miles, when engine is very warm, details in other thread)
Old Oct 27, 2006 | 02:41 PM
Jeff92se's Avatar
Red Card Crew
You guys ever find out what the cause was/is?
Old Oct 27, 2006 | 02:42 PM
shaigh's Avatar
Check this thread: https://g35driver.com/forums/g35-sedan-v35-2003-06/75477-05-6mt-engine-knocking-pinging.html
Old Oct 27, 2006 | 03:15 PM
absolutg's Avatar
workin...
i've read that thread. everyone refers to it but no one explains exactly what it is
Old Oct 27, 2006 | 03:18 PM
Linky
Old Oct 27, 2006 | 03:42 PM
6MTzer's Avatar
1. ByThaBay
2. Fini
3. zipzow
4. jeffy1
9. 6MTzer (low rpm's, comes and goes, usually when the outside temp is hot.)Motordyne Plenum Spacer.
Old Oct 27, 2006 | 03:45 PM
ttrank's Avatar
Grocery getter
It's when there is too much heat and pressure in the combustion chamber and the fuel ignites before the piston has moved all the way back up and the spark plug has fired.
It basically sounds like hundreds of tiny metal ***** being poured onto a piece of tin.
