how'd you stop the car when you turned off the car? didnt you say u were slowing down from 80? and im pretty sure you didnt pull the e-brake since your still here typing. Did you slam on the brake pedal with the car off??
Quote:
I was able to cut the speed in half by stepping on the clutch to disengage the engine from the wheels and then started braking. I quickly brought the speed down to about 40mph but unfortunately couldn't wait any longer because the engine was pounding on the rev limiter. I decided to take a chance by shutting the engine off and apply force on the brake pedal. I knew I would lose hydraulic pressure once the engine is off, but I didn't want to damage the engine either.Originally Posted by dream_G35
Quote:
No kiddin'. That plaza at the T-intersection sure looked like one big final destination... For a second or two I thought I'm gonna ram into that place and exit the back door. Originally Posted by EQUATE
Bro you got some Final Destination **** going on their.
First of all, a big thank you for this thread. I read it a couple of weeks ago and guess it stuck in my head. Had a similar experience the other day but fortunately I was on a straight empty road and was not going very fast (yet). When the gas pedal stuck during a shift, I immediately remembered to shut it down before any engine damage occurred. In my case, I'm guessing the culprit was aftermarket all-season mats. Did you ever get a probable cause for your gas pedal sticking?
Update:
Car is at the dealer. Just got a call from the dealer saying that they can't find anything wrong with the gas pedal but that is does make noises.
The dealer is ordering a new gas pedal assembly.
Everyone is claiming that it is a floormat thing. Doesn't your car have the hooks to keep the mat from sliding forward? I know my '03 5AT does, but maybe you're using a different floor mat. Definitely have the dealership check it. It could be a bad throttle cable or something, or computer problem. Honestly I don't even know if our cars use throttle cables anymore, probably computer.
**Edit - Yeah, i guess I didn't read the last page of posts. It's been covered. Glad you're ok. At least you got a nice addrenaline shot. like nitrous for your head.
Sounds like your pedal got stuck. It may need to be lubed or something. But damn thats some crazy $hit
This may seem like a dumb idea, but instead of downshifting and rev matching and turning the engine off did you ever think of hitting the brakes?
Quote:
totally agree with that, floor mat can block your gas pedal or brake!!!Originally Posted by codeflux
i had a similar situation. had to throw the car in neutral and kill the engine, then slow down without power brakes or power steering. check your floor mat - it may have slid forward and saught on the pedal.
yes, it does have a hook to it but for most of us, we use extra floor mat...the rubber kind to keep the dirt/mud above the original infiniti's mat. That rubber layer is the problem!!Originally Posted by Heikes
Everyone is claiming that it is a floormat thing. Doesn't your car have the hooks to keep the mat from sliding forward? I know my '03 5AT does, but maybe you're using a different floor mat. Definitely have the dealership check it. It could be a bad throttle cable or something, or computer problem. Honestly I don't even know if our cars use throttle cables anymore, probably computer.**Edit - Yeah, i guess I didn't read the last page of posts. It's been covered. Glad you're ok. At least you got a nice addrenaline shot. like nitrous for your head.
