06 G35 Burning 4 Quarts Of Oil
Old Nov 14, 2006 | 09:31 AM
  #31
V35 Skyline GT's Avatar
6MT Coupe
Fair enough....
You are one of the lucky ones without the oil issue. 2005's are also in the mix of 2006's with this problem.
It seems to be primarily with the revup VQ's, 6mt's. 5AT's (non-revup) don't seem to have this problem as much.
Here's a poll done about this:
https://g35driver.com/forums/engine-drivetrain-forced-induction/120735-poll-oil-consumption.html
Old Nov 14, 2006 | 09:36 AM
  #32
gspotter's Avatar
Originally Posted by runningonmt
The following is an excerpt from the 2006 Infiniti G35 warranty:
WHAT IS NOT COVERED
DAMAGE, FAILURES OR CORROSION DUE TO ACCIDENTS, MISUSE OR ALTERATIONS
This warranty does not cover damage, failures or corrosion resulting from:
• Accident, theft, fire, driving through water (including engine
water ingestion) or misuse. (Proper use is outlined in your OWNER’S MANUAL.)
Alteration, tampering or improper repair.
• Glass breakage, unless resulting from defects in material or workmanship.
Installation of non-Nissan approved accessories or components.
• Improper installation of any Nissan approved or aftermarket accessory or component.
The dealership wants to keep you as a repeat customer, so it's in their best interest to extend warranty coverage that doesn't cost them a dime to provide. However, it isn't the dealership that provides the warranty; it's Nissan, and Nissan will be the one footing the bill for whatever parts and labor are required for the dealership to repair the vehicle. Nissan isn't as likely to care about denying a claim to and risking the loss of one individual customer, particularly if they believe they're justified in their refusal.
Magnuson-Moss is not a panacea. It doesn't prevent the warrantor from denying all warranty claims, just those whose denial is contrary to the provisions of the Act itself and/or in violation of applicable state and local law. Maybe, because it is an "upscale" brand, Infiniti is less likely to attempt to deny warranty coverage than other manufacturers with which I have personal experience. That doesn't mean they can't or won't. Nevertheless, it does seem like there's a disproportionate number of 2006 G owners reporting excessive oil consumption, so I agree that it appears to be the result of an apparent manufacturing defect, albeit one that may have been exacerbated at least in some cases by hammering on the motor.
The key words are RESULTING FROM. It doesn't say they will immediately deny warranty if there are mods.
Old Nov 14, 2006 | 12:14 PM
  #33
Hexxum001's Avatar
That's exactly the point. They can't simply look at your car and see you have mods and deny your warranty. If they did that, they would absolutely lose in court. By law, they have to prove that whatever mods are on the vehicle contributed or directly caused the problem at hand. This oil consumption issue is becoming more and more common. Any dealer would be foolish to try to deny someone's warranty for oil consumption whether the vehicle is modded or not. It is such a widespread problem that I would think that they would rather just fix it than to risk getting any negative publicity for an ever growing issue. If someone brought in a G with a blown engine and there is a blower sitting on top of the engine, then yes, I could understand the dealer denying something like that.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
