Service engine light
Old Nov 6, 2003 | 08:52 AM
oldbread's Avatar
Since i had my car i for it's first service, when my gas tank gets down to less than 1/4 full(or empty) the light comes on, then when I fill up after a few trips it goes out, now this doesn't alway happen evey time it gets low on fuel. Anyone else had this experience, so far it doesn't seem to be a problem so I figure I'll wait till next service unless I hear otherwise.
Old Nov 6, 2003 | 09:22 AM
jdking's Avatar
Re: Service engine light
It is most likely due to not having you gas cap on tight. You must be sure to tighten it until it clicks, otherwise it'll cause the Service light to come on. If not, check the cap to be sure it is not defective, ie: screwed up threads or bad seal area.
Dealer should replace it for free if nothing else.
JD
2003.5 Coupe, Blk/Blk
Old Nov 6, 2003 | 09:44 AM
oldbread's Avatar
I always make sure it click, but the light coming on doesn't happen all the time. It hadn't done for a moth or so and came on this am.
I read something also on www.nissan-techinfo.com/infiniti re: TSB's regarding something to do with automatic trany & Check engine light coming on but no more details, anyone heard of this one
oldbread - 03 Perf, Bk/Blk
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Ednica87
Sep 5, 2015 02:59 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
