I hear a strange noise, never heard it before.
Old Dec 11, 2006 | 08:40 AM
logik05se's Avatar
Ok, yesterday i heard this noise that is definatly new to me. It's not the clutch chatter noise but is similar to that sound just not exact. The sound happens only when my rpms are around 3k. Strange thing is, lets say i start rolling from a stop in first gear, the sound wont happen when the rpms go from lets say 2k to 4k rpms, but rather when i let off the gas and let the car slow down by itself, so from 4k its quiet and then once it hits about 3k you hear this sound that sounds almost like a fan hitting plastic, then it goes away when you drop under 3k. Car drives fine i just have no idea what this is.
Old Dec 11, 2006 | 11:29 AM
ndlive's Avatar
is it like metal scraping agaist each other bad in the wheel/suspension area? like the wheel's scraping against something while its spinning? i had the same problem a few days ago (scared the **** out of me) when it first snowed. only at around 4th gear 2k and slowing down. i could still hear it some when accelerating and at lower speeds as well, but it was like the tires were spinning faster at higher geras/rpms hence faster spinning/scraping and louder sound.
anyway, i hit a small pothole with my passenger side wheels and it went away
Old Dec 12, 2006 | 02:39 PM
nuttyprof's Avatar
i have the same problem. was about to post about it until i saw your post. DOES ANYONE KNOW. IM FREAKED OUT!!!
btw, it is also around 3k. at first, it happened only when i stepped on the clutch or let off the gas. now, it makes it on its own. Its very quiet and sounds like waves (ocean). a slight chattering sound.
Old Dec 12, 2006 | 02:46 PM
nctrnlsilvia's Avatar
mine did something like that and it turned out, to be one of my cateletic converters, I would recomend you guy to get it checked out first though
Old Dec 13, 2006 | 04:25 AM
nuttyprof's Avatar
hmm, interesting. I have aftermarket cats, so that could very well be it. time to get some new oneS!!!
Old Dec 29, 2006 | 05:23 PM
nuttyprof's Avatar
OMG, i found out what the noise was. Turns out, it was my engine knocking. I had only half a quart of oil left in my car. Im lucky I didnt blow my engine. Scary.
Old Jan 16, 2007 | 03:41 PM
AZG35TT's Avatar
'04 G35 C TT. On a cold starts where the car has been sitting for several hours I have a whistling or humming sound (sounds like a tea kettle) from 2k-3.5k pulsing and changing intensity with throttle imputs. If I depress the clutch or take it out of gear the car still makes that noise as the rpms drop through that range. After the car has been on and driven for a few minutes the sounds becomes less intense and eventually goes away. I have had my car into the dealership on several occasions, even leaving it for the service manager to drive to and from work, they have been unable to locate the problem.
Does this describe the problem as others are having it?
Old Jan 16, 2007 | 06:46 PM
uberchicken's Avatar
as soon as I read this I had a feeling. I had the same problem!
Old Jan 25, 2007 | 02:34 PM
rclee820's Avatar
I'm having the EXACT same problem in my 04 Coupe. A tech told me that it's the throw-out bearing, and my clutch. Its at the dealership right now as I type getting those items replaced. I'll let you know if it solves the problem.
Old Jan 26, 2007 | 01:32 AM
AZG35TT's Avatar
Sounds good.
Old Jan 28, 2007 | 12:37 AM
rclee820's Avatar
alright so here's an update:
I picked up my car this morning from the dealership after having my clutch and throw-out bearing replaced. Paid $920 for it, and left. I drove about 3 miles, and I noticed the noise was still there... turned right back around and gave it back to them and had them refund my $920 until they figure out what the problem is. Unfortunately the service dept. wasn't open today, so I'll have to wait until Monday to get any more details. Those bastards... my clutch was fine!
Old Jan 28, 2007 | 01:52 AM
ndlive's Avatar
damn that sux man
plz keep us updated on what happens. hope everything goes well
Old Jan 29, 2007 | 10:10 AM
rclee820's Avatar
Update:
So I get a call from the service manager this morning telling me that the noise was completely normal, and that he drove several new G's that make the exact same noise, only not as loud. Now, this presents the question "If the noise is completely normal, why was I charged $920 to find that out?"
Secondly, I had my 60k service done at nissan. Inifniti was blaming nissan saying that the tranny fluid they put in was the wrong one, and was too thick. I checked with nissan corporate, and they verified that the tranny fluid for the 350z and the G35 have different part numbers, but they are in fact the same. The Infiniti service manager was saying that this "wrong" transmission fluid is causing damage to the syncros... now that we've established that the correct tranny fluid is in there, doesn't that mean the syncros were damaged all by themselves?
Ultimately, if my syncros are bad, I have this whistling/howling noise that won't go away, and I am within my powertrain warranty, doesn't this entitle me to something?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
alinero718
Sep 27, 2015 09:35 PM
