safe to park in an incline without e-brake?
Old Dec 28, 2006 | 05:28 AM
G-MENTED's Avatar
Originally Posted by BroDaJin
I think he meant that his parking brake failed.
im glad a few of you were actually reading my post correctly.
my parking brake is not working. had a recall done at infinity of pleasanton and i think they didnt adjust my parking brake after working on it. when i pull it all the way up, my car still rolls back. thus... the question being... will it be ok to only leave the car in gear when parked in an incline for a week.
anyway... im back and the car did not roll back. time to get the parking brake adjusted.
Old Dec 28, 2006 | 01:38 PM
gladiac2k1's Avatar
Anybody know how to adjust the e-brake without having to take it back to the stealership??
Old Dec 28, 2006 | 01:55 PM
bull3t's Avatar
Originally Posted by CruisnGcoupe
my parking brake is garbage is there a way to adjust it
yes there is a way to adjust it...for my 03 6mt there is a nut and bolt under the ashtray...my ashtray is right behind the shifter console...i'm sure it's different in
newer models...you guys might want to change your brake pads first though...because later on when you change pads the distance you have to pull
the e-brake is going to be really short...so if you change your pads and the pulling distance is still to high then i would recommend tightening your e-brake...
Old Dec 28, 2006 | 03:24 PM
Dubfound's Avatar
Originally Posted by G-MENTED
I parked my G up on the driveway. I pulled the parking brake up and the minute I let go of the brake pedal, the car started rolling back. I hit the brake, pulled up the driveway again, and this time... I put it in 1st gear to keep it from rollin back.
Will leaving it parked in 1st gear for several days without the parking brake be alright?
I left my 91 Integra on a medium size grade once with no e brake and in first. It popped out of gear after like 2 hours of being parked and rolled into a tree! The worst part is I was outside cutting the grass and watched the whole thing go down. I was like “Um.. Holly $hit my car is rolling!” I ran over to it to stop it and grabbed the little factory spoiler and ripped it off. HaHa. Funny now, but I was so pissed!
So, No I never park my car without the ebrake!
Old Dec 29, 2006 | 02:24 PM
G-MENTED's Avatar
how exactly did you adjust it? maybe i can do it without taking it to the dealership too. i heard it only takes 15 minutes to do. i also have a 03.
Old Dec 29, 2006 | 03:08 PM
6MTzer's Avatar
I always use the parking break, just a habit I guess. Am I the only one?
Old Dec 29, 2006 | 03:12 PM
Bigd2k6's Avatar
that's terrible but funny at the same time. i always put it in 3rd and use the e-brake. so leaving it in 1st or R is better than any other gear because of the gearing if something did happen to fail and start rolling?
Old Dec 29, 2006 | 05:01 PM
bull3t's Avatar
okay remove your ash tray and then just tighten the bolt that is in there...you'll need a deep socket for the nut
Old Dec 29, 2006 | 06:01 PM
gladiac2k1's Avatar
Hehe thats what she said!
Old Dec 29, 2006 | 06:24 PM
Aman's Avatar
I have always let the car sit on the gear, and then use the e-brake for what it is for: in case of emergency. That way your car is using the tranny to keep the car in place, but have the e-brake to catch the car in-case it slips out of gear.
So when you park, put your car in first or reverse (depending on which way your car is facing on the hill) and once the car is stopped on the gear, apply the e-brake. And like others have said, if you yank the e-brake to where its almost vertical, you are going to make it less and less effective. Just apply what is needed.
Old Dec 29, 2006 | 06:40 PM
kennyz424's Avatar
Engage the parking brake first and then put it in 1st gear. Let the tranny be the backup just in case the parking brake fails.
Couldnt have said it any better... ^^ ++111 ^^
Old Dec 30, 2006 | 03:15 AM
G-MENTED's Avatar
so i dont have to adjust anything? just tighten the bolt?
jeffbdye
Jun 1, 2018 03:51 PM
KallDay86
Jan 8, 2016 12:42 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
Blindside360
Sep 18, 2015 09:00 PM
