V1 concealed display in air vent.
Old Dec 28, 2006 | 05:37 PM
filanj's Avatar
Originally Posted by 04Rg35
Filanj was it hard to put the display where you did?
Also would it be hard to put a mute switch in the cup holder next to the e-brake?
it would be very easy, but i don't ride around with the holder open all the time. I put it where I put it for simple touch and closeness to the shifter. To have to reach down into the holder isn't as seamless as it seems.
Old Dec 28, 2006 | 06:49 PM
04Rg35's Avatar
Do you know how i would wire the remote mute buttom? Would i run from my concealed display? I am not very good with wiring.
Old Dec 28, 2006 | 06:52 PM
g35rcr's Avatar
the display has a split connector for the wires to connect to...plug and play
Old Dec 28, 2006 | 06:55 PM
filanj's Avatar
you need a RJ-11 extention/splitter.... basically looks like two plug-ins on one side and one plug-in on the other. you need a short wire to run from the hardwire kit or another RJ-11 connector (however you have it hardwired) to connect to the extention/splitter. it will not work with a regular splitter...you need the extention/splitter
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
