Stalling after start
Success at last. I cleaned the throttle body with MAF cleaner. At first Glance at the throttle body it was almost pitch black inside. I figured out that there should be a small 1/2mm Gap at the ends of the throttle circle itself and when Carbon Blocks that tiny gap - the car had difficulty being at idle- therefore it will be more prone to stall out. Now, THIS is key! . I DID NOT disconnect my throttle body from the sensor connector - Therefore I did not have to do any of the RELEARN procedures! After cleaning the Throttle body and bolting it back onto the intake manifold - I started the g35 up and . It was Puuurrrrfect! I also cleaned a little inside the Intake manifold itself due to it being very dirty at the inlet...
I just started to have this problem yesterday evening...exactly the same situation...on ignition starting the car...it either will die out or idle under 1000rpm...and thats when i had the car running for a long time...woke up this morning started the G up and no problem...so im cleaning out the TB this weekend...I have to say the forum really helps out a lot...thanks alot guys! oh, btw...where do you get MAF cleaner...??
For those of you having this problem:
I had a very similar problem after replacing my battery.
On cold starts, it would start up fine. But, on hot starts (i.e. after driving, shutting the car down, and then starting again a short time later) the RPMs would go up and then just gradually drop to zero.
My mechanic did an idle re-learn and the car was perfect.
Good luck
Good luck
i think it's either you need a new throttle body, throttle position sensor, or you need to clean your throttle body...since your warranty is probably up try cleaning your throttle body
first...since you have no check engine light my guess is a dirty throttle body...and check if your maf is dirty too...
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
kevintandmd
Sep 3, 2015 06:41 PM
