a few newbie questions
Old Dec 30, 2006 | 04:05 PM
French87's Avatar
im not very car savvy at all and have a few questions that may seem stupid to you guys, but here goes
1, what is the difference between a revup and a norev engine? which is better and how do i know which i have
2, what do spacers do?
3, FI = forced induction right?
i may add some more
Old Dec 30, 2006 | 04:15 PM
johnbigbootie's Avatar
Rev-up is a motor that's available on 05+ manual transmission G's; the peak hp is increased from 280 to 298 and it has a higher redline.
Spacers sit between the upper and lower sections of your plenum (air intake, it's under your plastice engine cover). The stock plenum has a smaller air space in the front by design, so the spacer increases the volume of air inside your plenum which results in a hp increase.
Yes, FI = forced induction (supercharged, turbocharged)
Old Dec 30, 2006 | 04:17 PM
s2k_g35's Avatar
^^^^perfectly stated.
Old Dec 30, 2006 | 04:18 PM
French87's Avatar
hmm thanks,
i also saw something about spacers on wheels, im assuming these just push the wheels out a bit?
Old Dec 30, 2006 | 04:30 PM
Nismo G's Avatar
The red should be plenum. Your air intake is different.
Old Dec 30, 2006 | 08:52 PM
Calvin's Avatar
Overglorified Altima
Originally Posted by French87
hmm thanks,
yes
spacers are bandaids
get wheels with the right offsets to begin with
Old Dec 30, 2006 | 11:07 PM
French87's Avatar
well i saw someone talking about putting spacers on OEM 19's. are you telling me the wheels taht came on my car arent set right? ..
Old Dec 30, 2006 | 11:53 PM
limeg35's Avatar
They do that to push the wheel out a bit so the wheel are flushed with the fender or so the wheel might clear the aftermaket big brake kit/suspension...
Old Dec 31, 2006 | 01:05 AM
wilksoner's Avatar
they might be putting spacers on oem 19 to fit a big brake kit so they have enough clearance
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
