Mobile 1 Oil Filter
Mar 5, 2007 | 02:19 PM
Im due for an oil change. I just bought 5 qt of the German Castrol and just wonder what filter to use. I was looking at the M1-108 filter, which is recommended for the G, but it looks kind of small. The M1-110 looks the same but a little longer. Is it ok to use the M1-110 instead? And are there any advantages using the longer version?
Reply 0
Mar 5, 2007 | 02:35 PM
Use the m110, or a puralator pureone
Reply 0
Mar 5, 2007 | 02:38 PM
Quote: Use the m110, or a puralator pureone
Which pureone? The PL14612 or PL14610?
Reply 0
Mar 5, 2007 | 02:47 PM
PL14610...slightly longer
Reply 0
Mar 5, 2007 | 03:38 PM
I use the longer Napa Gold version (aka Wix). But depending on your changer interval, it most likely won't matter. I change every 3-4k so I'll admit, either filter would work for me but I use the longer one anyway.
Quote: Im due for an oil change. I just bought 5 qt of the German Castrol and just wonder what filter to use. I was looking at the M1-108 filter, which is recommended for the G, but it looks kind of small. The M1-110 looks the same but a little longer. Is it ok to use the M1-110 instead? And are there any advantages using the longer version?
Reply 0
Mar 5, 2007 | 03:41 PM
I use the 110.. but I just bought a 108 sine they were all out of 110's lol..
If you have a few bucks extra you can get the KN oil filter too.. They are the design as the M1's.. but they are soo much easier to take off with the hex bolt on the end of it!
Reply 0
Mar 5, 2007 | 03:44 PM
^^ strap wrench FTW
Reply 0
Mar 5, 2007 | 04:39 PM
Quote: ^^ strap wrench FTW
I saw a mechanic do it with just his bare hands and a shop rag before. INSANE!
Reply 0
Mar 5, 2007 | 05:01 PM
M1 and pureolator have similar filtering capabilities, however purolator is half the price. Try pep-boys I stocked up on purolator filters when they had a mail in rebate got 5 at $2.xx a piece.
Reply 0
Mar 5, 2007 | 05:03 PM
German Castrol is great oil. I see we are both in Chicago, which autozone you get it at?
Reply 0
Mar 5, 2007 | 05:10 PM
Good recommendations fellas, I too was wondering which to go with!
Reply 0
Mar 5, 2007 | 06:34 PM
Quote: I saw a mechanic do it with just his bare hands and a shop rag before. INSANE!
why is that insane? I do that all the time, and I don't need to use a shop rag. If your filter is so tight, that you have to use a wrench to take it off, you put the filter on way too tight.
Especially with the M1 filters, the silicone gasket doesn't need much pressure to seal. I just hand-tighten it a 1/2 turn.
Reply 0
Mar 5, 2007 | 08:56 PM
Mobil 1 Oil With A Mobil 1 Oil Filter.
Reply 0
Mar 5, 2007 | 08:58 PM
German castrol and m1 oil filter. FTW
Reply 0
Mar 5, 2007 | 09:01 PM
Quote: Mobil 1 Oil With A Mobil 1 Oil Filter.
https://g35driver.com/forums/engine-drivetrain-forced-induction/143074-mobil-1-oil-users.html
Reply 0
