Will 350z springs fit G35C
Re: Will 350z springs fit G35C
It will fit perfectly, but it does not have the same spring rates. So you might go lower than what is shown for the 350Z.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
yup, i have RSR springs on my car.
Nismo Swaybars, TS ECU, Blitz Filter, Sun Auto Hyperground w/ Voltage System, Data Systems front lip,Gialla Front Grill, Volk LE37T
I think I'm going to switch springs with my brother so I can go lower. He has the eibach pro kit on his 350z. Damn people gave me sedan springs, thats why the rear of my coupe is raised. Looks retarded.
will that help me I have a coupe lowered but now with my system my car is to low in the back So will sedan springs help or should I put the stock springs in
leave it alone. That gap looks perfect. Or is the rake way off?
BS G35C 6spd navi/aero/prem
The rake is off a little bit but most of all I drag on speed bumps and some parking lots that picture is right after it has droped a little more I cant even put my finger under there anymore
RaySur350GT (Addict)
12/09/03 07:44 PM
__________________________________________________ _
Not true, they use the same springs, same rates. So installing OEM 350Z springs on a coupe would be a pointless waste of money and time. The only differance is in the valving of the struts between the cars, with the Z getting significantly more compression dampening. Also both cars have the same shorter dampeners and springs than what the sedan applications use. In addition the Nismo S-tune is the same for both cars, running spring rates of 448lbs front and 504lbs rear
Stock spring rates
F/R in lb/in
350Z and G35 coupe: 347/419
Notice how the rates are with a couple of pounds of the RSR springs which are 345LBS front 417LBS rear
A further examination of Z and G35 coupe spring rates as applied by the aftermarket reveals are wide range of thinking on how to turn the car with their spring rates.
Eibachs
350Z 296/384 front 316/421 rear
G35c 229/337 front 274/463 rear
Kg/mm springs for 350Z
http://www.kgm.co.jp/catalogue/dr21/...FIARLADY-Z.htm
DR21 super sport 15mm drop
260/419 front 266/431 rear
DRacing 30mm drop
266/478 front 266/507 rear
"i, for one, am not a fan of glory hounds."
Dang straight, it's all about the glory of helping. Who have you helped today?
12/09/03 07:44 PM
Stock spring rates
F/R in lb/in
Eibachs
DRacing 30mm drop
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
