Check Engine!!! WTH!
Old Mar 21, 2007 | 07:53 PM
6MTzer's Avatar
Great,
I start driving to work today and the check engine light comes on, the car is vibrating and I hear some weird noises coming out of the engine.
What the hell can this be? I had the oil changed two days ago and it is at the proper level.
The worst part is I can't take it to the dealer until I find time to take the spacer off.
Old Mar 21, 2007 | 08:04 PM
SPEEED's Avatar
Bad Toro
Sounds like they forgot to tighten something up...
Old Mar 21, 2007 | 08:24 PM
VinNYCG's Avatar
G SQUAD
Damn that sucks..Hopefully its nothing big. It should be something the dealer forgot to do considering it was only there two days ago.
Old Mar 21, 2007 | 08:39 PM
jjyellow's Avatar
Leave the spacer on and take it to the dealer, they wont notice it
Old Mar 21, 2007 | 08:48 PM
6MTzer's Avatar
I took it in once for pinging and they would not touch it with the spacer on. They claimed it would throw all their readings off.
The dealer did not change the oil either.
Old Mar 22, 2007 | 02:36 AM
slikmo22's Avatar
East Brunswick??? I go to rutgers there ....anyways did u check ur oil level and look for anything suspicious under the hood?
Old Mar 22, 2007 | 02:44 AM
imalazeeass's Avatar
dealerships are such noobs sometimes
Old Mar 22, 2007 | 07:30 AM
6MTzer's Avatar
Yes, the oil level looks good and I do not see anything unusual under the hood.
As far as the spacer, can somebody tell me, is it just a matter of removing the bolts, removing the spacer and replacing the original shorter bolts?
Do I need to buy a new gasket or anything else I may have over looked?
Thanks.
Old Mar 22, 2007 | 11:56 AM
slikmo22's Avatar
I dont think you need a new gasket just make sure you torque the screws right
Old Mar 22, 2007 | 11:59 AM
izmir41500's Avatar
G35driver Addict
yes they are. my car was at the dealer collision center for 5 days, then they decided that they didn't want to risk putting on my aftermarket bumper. All they needed to do was some simple modifications and paint the dang thing.
Old Mar 23, 2007 | 12:06 AM
Leo350GT's Avatar
same thing happened to me when i changed my oil..check if they put oil lever on right
Old Mar 23, 2007 | 06:53 AM
6MTzer's Avatar
I'm not sure what an "oil lever" is. Do you mean filter?
Old Mar 23, 2007 | 07:00 AM
advancetek's Avatar
check your intake and all other hoses are you sure you don't have a vacuum leak.
Old Mar 23, 2007 | 08:01 AM
6MTzer's Avatar
I did look it over, but need to recheck again. The job is consuming all my time, so for now it is sitting there while I drive my truck.
I did hit a big pot hole on my way back from NYC, I don't think that could have caused these symptoms though.
Kng0fHrts
Sep 15, 2015 05:40 PM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
