shift knob
Old May 6, 2007 | 06:18 AM
cchaorule's Avatar
shift ****
i removed my shift **** to install my short shifter.. now i dont really know how to put it back properly.. there is a copper metal ring and a rubber ring.. which goes on first?? do you put it on the shifter then twist the **** on.. or do you put it inside the ****.. any help is appreciated.. thanks
Old May 6, 2007 | 09:39 AM
Rphillips6487's Avatar
this will help you with the metal ring:
http://www.rogueengineering.com/pdf/...er_install.pdf
as for the rubber ring, I just pushed it back into the **** itself before screwing it back on because its supposed to be there either way.
metal ring first, the the rubber ring should be next (aka the **** itself)
good luck!!
Old May 7, 2007 | 01:58 PM
gary c's Avatar
****/Shifter..........Fun!
Doing installs is kinda like the old days when you took a carb apart. You lay
thing out in the order you remove them. That way when you're putting it
back togeather it's a simple process. Since you have the short throw shifter
you should do a search and check out some of the cool aftermarket *****
available from people like Momo and others!
Picture Share
Feb 4, 2018 12:41 PM
Tmatheso
Dec 13, 2015 03:24 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
