Removing XM antenna
Old May 14, 2007 | 10:30 PM
shelbyboy's Avatar
Removing XM antenna
The G coupe I just purchased has an XM antenna mounted on the roof. The previous owner said it was a factory kit and is held by two sided tape. I mean it is really held. To me it looks like a periscope on the back of the roof. I would like to get it off and replace it with a smaller version but am worried about pulling the paint loose. Any Ideas?
Cheers
Old May 18, 2007 | 05:07 PM
filanj's Avatar
Use a hair dryer to slowly heat it up. After a short time it should be pliable.
Old May 18, 2007 | 05:57 PM
BadBoy06's Avatar
heat + dental floss works great. then get you some adhesive
remover for left over glue//polish/wax or seal = love/love
Old May 19, 2007 | 02:31 AM
patrickwong's Avatar
it's going to screw up your paint job
Old May 19, 2007 | 02:38 AM
BayAreaRefuGz's Avatar
i fly low
if it is adhesive/two-sided tape then you can use a hair blow dryer + dental floss. then use Goo Gone to remove the adhesive. then wash it with soap and water (preferably wash the whole car) then wax it. should look like it wasnt even there in the first place.
go to the search button and put in "debadging"
it's kind of like that, but except do it to the XM antenna..
Old May 19, 2007 | 02:56 AM
ttrank's Avatar
Grocery getter
^+1
That will work.
If it has been on for a long time there may be a little fade in the paint around it but I would still do it.
Old May 22, 2007 | 05:05 PM
shelbyboy's Avatar
Thanks for the opinions. I like the dental floss idea. Can't say what brand but it is two sided tape. GooGone won't hurt the paint?
I am considering selling it so I won't do anything just yet.
Thanks for the ideas
Old May 22, 2007 | 08:23 PM
EricIsKlumzyee's Avatar
use a heat gun and a dental floss.. (hair dryer and dental floss if you dont have a heat gun)..
ITS THE TOP OF THE CAR WHO CARS ABOUT PAINT FADE -_-
googone WILL hurt the paint if you rub against the paint with it with pressure or if you let it sit on the paint..
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
dcsbh1
Oct 1, 2015 03:15 PM
