After 28,000 miles
Old May 24, 2007 | 08:34 AM
gto2050's Avatar
Lightbulb After 28,000 miles
what is the solution to front tire cupping, feathering and all the other issues for the coupe? Do the new ones have the same issues as the earlier ones? I have an 03 6MT and I just changed tires. I knoew they were cupped but I refused to change until I got my money's worth out of them. Now I have Yoko AVS ES100's and they are quiet.
Can the car be put into proper alignment? Is a camber kit ($846 just for parts!) the answer?
Old May 24, 2007 | 12:28 PM
TheKnite's Avatar
I rotated my wheels and dismounted and remounted the tires so the inside is now the outside. Front tires have about 40k miles and are still good. Who said you can't rotate tires on the coupe? It's possible it just costs more.
Old May 24, 2007 | 12:39 PM
g35rcr's Avatar
never had cupping at all with my stock setup or my new setup...i didnt break donw my tires left - right and still got 30k miles out of my pilots and 30 out of my kdw's driving them hard
Old May 24, 2007 | 12:42 PM
savefatkids's Avatar
i had the same problem as you.. got about 8k out of my pilot sports...if it bother you that much. just get a camber kit i suppose
mike281's Avatar
Mike Team350GZ
TheKnite.... you cant properly rotate the tires on the coupe. They are staggered so you cant put the backs in the front and fronts in the back, they are different sizes. Which is an actual rotation of the tires. I mean you could just switch side to side but thats not a true tire rotation.
Old May 24, 2007 | 12:46 PM
TheKnite's Avatar
I don't think you needed to explain that, everyone knows you don't put rears in the front if you're staggered. But thanks anyway, and yes I mean side to side, but I did still rotate the tires on the wheels.
Old May 24, 2007 | 01:12 PM
g35rcr's Avatar
you dont really get much more out the tires by swapping left to right
Old May 24, 2007 | 01:53 PM
mike281's Avatar
Mike Team350GZ
ya thats kind of the point i was trying to get across
Old May 24, 2007 | 02:01 PM
TheKnite's Avatar
You don't if you're wearing them evenly. I answered the guy's post because we have cupping/feathering problems, where inside of the tire wears down the tread while the outside has still a lot left. When I noticed my uneven wear I was giving my front tires another 10k at the most, but by rotating the inside out I made another 20k and got room to go, and when this side gets lower than the other I'll probably rotate them back again.
Do whatever you guys want, I just wanted to enlighten the guy so he knows he has options. It helped me so wanted to pass on the helpful information onto others.
Old May 24, 2007 | 07:45 PM
jgainnm's Avatar
My tires rotate every time I drive the car.
Old May 25, 2007 | 10:42 AM
bocatrip's Avatar
AGREED!
Old May 25, 2007 | 09:21 PM
EricIsKlumzyee's Avatar
cuping = toe not camber
camber causes an uneven wear
toe casues cupping / feathering
sorry if you guys already covered this.. SPC toe bolts will fix this
Old May 26, 2007 | 06:54 PM
gto2050's Avatar
More info on toe bolts? Expensive? Where available? Thanks. That's the input I was looking for!
Old May 26, 2007 | 07:19 PM
bocatrip's Avatar
What is a toe bolt?
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
linedr89
Aug 17, 2015 05:11 PM
Jroc2017
Aug 12, 2015 11:21 AM
