Headlights aimed too low?!
Old Jan 7, 2004 | 12:05 AM
fldrummer's Avatar
I've been noticing that when I drive on a dark stretch of road, I can barely see 50' in front of me w/ the low-beams and fogs all the way on. I can't believe this s***; aren't these HIDs supposed to be really bright? I think they're just aimed too low. I let the service dep't know about it today when I took the G in for its first oil change and they claim they adjusted them (BS! I just drove again tonight and didn't notice any difference; grrr!). Does anyone know how to adjust the headlights; 'looks like I'm going to have to do it myself. *sigh*
2004 6MT (Silver/Willow), premium & aero packages
My old ride (I still miss her; put a lot of pride and joy into it): http://www.n-body.net/registry/john95ga/
Old Jan 7, 2004 | 12:23 AM
Shader7's Avatar
Re: Headlights aimed too low?!
You can indeed adjust your headlights, with little or no trouble. Sometime between the 2003.5 and the 2004 models (to my knowledge) Infiniti started putting caps over the adjustment access hole for some reason. Some people, after taking their cars in for service, even found these caps newly installed. If you have them, you can likely drill them or possibly pry them out.
In any case, the thread you want is here.
That should contain all the info you need. Be careful not to adjust them too high however. Some people have reported they cannot adjust them back down after going past a specific point. Perhaps that is why Infiniti is installing the caps now.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 7, 2004 | 02:26 PM
fldrummer's Avatar
D***; I probably have caps then (got mine in late September). Maybe that's why they didn't fix them. I'll check real soon though. If there ARE caps on there, I might just take it back and tell them to break them off or whatever they have to do and fix it because driving around like this is dangerous; I feel like I only have fog lamps on in the dark!
Old Jan 7, 2004 | 10:39 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
I've had my coupe 2 1/2 weeks, and the night I drove it home I noticed the exact same thing. Turning the fogs on seems to help a bit.
Old Jan 8, 2004 | 12:19 AM
fldrummer's Avatar
Not for me; I have the fog lights on all the time also.
Old Jan 8, 2004 | 12:34 AM
fldrummer's Avatar
When I popped the hood, I looked into the holes and saw a white plastic piece that had a slot in the middle that a flathead screwdriver could easily fit into, but it was still daylight, so I did not try it out yet. Does it sound like I have these "caps" or no?
Old Jan 13, 2004 | 11:45 AM
doorbell7942's Avatar
Sorry if this is stupid question but does 04 G35 AT coupe comes with fog light? I can only turn high beam on, where is the fog light switch???
Old Jan 13, 2004 | 11:57 AM
ncozby's Avatar
Every g35 has fog lights. The switch is right next to the headlight switch, its a little farther in on the stalk. Turns the same way the headlight switch does.
Fldrummer - If you can see the white gears, the caps are not installed, and you should be able to adjust easily.
<font color=blue>04 DG/G Coupe 5AT - St. Louis, MO
Premium, Aero, Performance, Splash Guards
Metallic Tint - 5-Wire Grounding Kit
MB Quart / Eclipse Stereo
PIAA Extreme Whites - K&N Drop-In</font color=blue><P ID="edit"><FONT class="small"><EM>Edited by ncozby on 01/13/04 08:58 AM.</EM></FONT></P>
Old Jan 13, 2004 | 09:16 PM
Merlin's Avatar
Staff ALUMNI
Noticed on some of the newer 2004s that the adjustment access hole is NOT covered from the factory.
Andrew, We Miss and Love You! Peace!
Old Jan 13, 2004 | 11:48 PM
Shader7's Avatar
I nominate Merlin for Mod-of-the-Month.
You can't have the fogs on by themselves BTW, they are only on if your lows are on as well.
350Z Nismo CAI
Old Jan 14, 2004 | 01:50 PM
fldrummer's Avatar
Well, it looks like there's a cap w/ a small hole on top. I can see some rigid white thing in there, but I haven't been able to turn it with anything (my screwdrivers were too big to fit in the holes, so I tried something else, but it kept loosing its grip.
Old Jan 19, 2004 | 10:10 PM
WRAH's Avatar
WRAH
I think I want to do this as well, but not that I got the caps off, I don't really know what to do. I too scare of braking something...
"What if there is no tomorrow....There wasn't one today!!!" Bill Murry
Old Jan 20, 2004 | 02:38 AM
RashMan1450's Avatar
HA HA HA guess what i got the caps off. I will do a DYI on taking the caps off. It took about 15 min but one set back is you have to take off the wheel and the inner wheel well.
Will have pics and everything soon.
One thing since i took off the caps. I STILL cant adjust it. Please someone help.
2004 Diamond Graphite G35 Coupe 6MT, Premium Package, Aero Package, DVD Nav
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
gatorglaze
Sep 10, 2015 12:03 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Jnm07
Sep 5, 2015 01:16 AM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
