Vents Off but Random burst of hot air????
Old May 25, 2007 | 12:03 AM
netcbc's Avatar
Hey all, I have the exact same problem as this guy
https://g35driver.com/forums/showthr...highlight=heat
but i'm not as "vocal" as he is i guess,
anyone found a solution to this?
Basically even when i turn vents off or switch it to blow out of the front window only, theres always hot air still randomly comming out of the leg area, it's quite annoying, as your driving and you can slowly feel hot air blowing into your face...
anyone have any success fixing this themselves?
Lets be honest, no dealer is going to even bother with this complaint, they'll just give you some look and go
Old May 25, 2007 | 12:27 AM
zeroscythe's Avatar
personally i think it has something to do with the mechanism that heats our seats... if u remove the carpet u'll notice the duct for the heated seat feature runs right next to ur right leg... it may explain the "busts" of hot air u feel next to ur legs... just a thought
Old May 25, 2007 | 02:07 PM
Memphis's Avatar
i started reading the link you posted but got bored after the first few f-bombs so i stopped reading it.
however, to address your problem, i recall a few years ago that someone posted that behind/under the battery box in the engine bay, the cabin air intake is located and that there is a large gap that allows this hot air you mention to be pulled in. people with the same problem as you were sealing up this gap to eliminate the hot air from coming in.
Old May 25, 2007 | 06:19 PM
netcbc's Avatar
Hey memphis this sounds like it might solve my problem, do you remember how'd they fixed it? do you have to lift out the battery somehow or?
Old May 25, 2007 | 07:20 PM
GreenGoblin's Avatar
The goblin resurrection
mine does it once in a while it is very annoying
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
