Ever heard of this?
Old Aug 2, 2007 | 11:56 AM
G35Hillbilly's Avatar
Ever heard of this?
I have an 06 6MT with 14,000 miles. I was driving last night for about 15 minutes with no problems. When I was getting on the highway, I downshifted to 4th and the car began to lose power - wouldn't even respond to me pushing the gas pedal. From that point, no matter what gear I was in, when I would get up to 2300 RPM the engine would surge violently, making the entire car buck (sort of like when you hit the rev limiter in a car). I finally pulled over, turned the car off and took a look (didn't see anything of course). Once I started it back up, it's been fine ever since.
I did drive through a massive rain storm earlier in the day, not sure if that matters. Also, I have the following mods:
AEM cold air intake
Motordyne MREV 2 (5/16" spacer)
Borla headers
Greddy true dual full catback exhaust
Any thoughts? Thanks for your help in advance
Old Aug 2, 2007 | 12:16 PM
Gdriver916's Avatar
Yeah somebody else was talking about this just the yesterday I believe. It's your throttle body. I guess it happens to a lot of Gs but hasn't happened on mine to be honest. Is it still under warranty?
Old Aug 2, 2007 | 12:18 PM
It should be under warranty for 4 years/50,000 miles
Old Aug 2, 2007 | 12:44 PM
Gdriver916's Avatar
Well then take it in and have them look at it. It should be a simple fix and a fairly common problem so don't worry about it. Call them up. Drop it off. Pick up a loaner *****. Have some fun with it and pick up your car the next (cleaned, Vacuumed and ready)
Old Aug 2, 2007 | 01:06 PM
I suppose I'll have to strip the mods off first. At least the air intake and the spacer. I was hoping is was something like moisture on the MAS from the rain.
Old Aug 3, 2007 | 10:23 AM
ISMSOLUTIONS's Avatar
It could have very well been the moisture...you could have loosened oil from the filter and the rain, and it could have done just that.
Pull the MAS and take a look first. Did you get a CEL at all?
Old Aug 3, 2007 | 11:03 AM
partyman66's Avatar
My guess is that it probably had something to do with your intake and MAF Sensor. There have been a lot of people posting about occasional random issues with stalling and loss of power at RPM's due to aftermarket intakes on our cars.
Old Aug 3, 2007 | 01:31 PM
mattyd54's Avatar
Yea I'd say its the MAF sensor on your intake tube. When i replaced mine i pulled outa my driveway and had the same exact thing happen when i couldnt pass like 2000 rpms. I opened my hood n noticed the maf sensor was unplugged. Jus make sure the sensor is plugged in securely and you should be fine.
Old Aug 3, 2007 | 07:44 PM
Waz350GT's Avatar
its called "limp home mode" and is a feature of all skylines nissan has made since the 1990s
if there's a problem with the signal from the MAF sensor then it runs the car very rich and doesn't let he car rev above 2500rpm to protect the engine. as it has no idea of the airflow it tries to protect from a fatal lean-out
probably a loose wire somewhere.. check the plug, maybe use some wd-40 on the MAF plug
Dallsinghjr1
Sep 17, 2023 11:25 AM
Rose M
Oct 12, 2015 10:00 AM
dcsbh1
Oct 1, 2015 03:15 PM
5150DS
Sep 26, 2015 07:47 PM
