Oil-drain valve
Old Feb 10, 2004 | 07:54 PM
Anonymous's Avatar
Oil-drain valve
Anyone interested in this oil-drain valve? Got one for my g35c It's about $30. You can drain your oil using a plastic tube (not included) which attaches to the nipple (optional) right into any container. Never have to unscrew the oil-drain bolt again...
Anonymous's Avatar
Oil-drain valve
Old Feb 10, 2004 | 08:16 PM
AirWarrior's Avatar
Re: Oil-drain valve
Where'd you get it from? (website)... and if the nipple is optional, how much does it cost?
I'm doing my oil change this weekend so I might go ahead and add one of those on there...
ace
Old Feb 10, 2004 | 08:27 PM
Anonymous's Avatar
Re: Oil-drain valve
Here's another photo. The nipple is like $3 extra. The website is www.fumotovalve.com
Anonymous's Avatar
Re: Oil-drain valve
Old Feb 10, 2004 | 08:33 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Oil-drain valve
Grubb's is selling them now in the maintenance page on their website. I bought one and use it with the hose. It's pretty cool doing an oil change and not spilling a drop.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Feb 10, 2004 | 08:56 PM
GR8TG35's Avatar
Re: Oil-drain valve
Does that valve have a lock or anything from preventing accidental release of the oil??? It looks pretty good...would sure be easy to do Oil changes....let me know..2old4this
04 cpe ivory pearl/willow/5at/prem/sport wheel pkg/clear corners/Piaa's
Old Feb 10, 2004 | 09:01 PM
GR8TG35's Avatar
Re: Oil-drain valve
one more thing....has anyone left that bottom engine cover off permanently...seems more work to take it off and back on than changing the oil and filter......2old4this
Old Feb 10, 2004 | 09:02 PM
ryoken's Avatar
Re: Oil-drain valve
Go to the website and read the specs on it. You have to push the lever up and then over to open it, and it takes a bit of force. It's not going to open accidentally.
Old Feb 10, 2004 | 10:51 PM
dopeymon's Avatar
Re: Oil-drain valve
so the g35 is not too low for the nipple right? i like the nipple with the tube to just drain all the oil into some jug
Old Feb 11, 2004 | 12:26 AM
RocketsRedGlare's Avatar
Re: Oil-drain valve
<<to just drain all the oil into some jug>>
..and take the jug someplace to be recycled of course.
On-On
S&S
Old Feb 11, 2004 | 08:09 AM
Deep Sea Moderator
Re: Oil-drain valve
That valve locks itself. It's a 2-step move to open it but they also sell a clip for it if you want.
The cover isn't that hard to remove. You only have to remove about 5 or 6 bolts to get to the drain plug and filter.
Russ
Black 6MT Coupe
Jax, FL
Old Feb 11, 2004 | 09:19 AM
GR8TG35's Avatar
Re: Oil-drain valve
Thank you for your feedback...2old4this
o4 cpe ivory pearl/willow/5at/prem/sport wheel pkg/clear corners/Piaa's
Old Feb 11, 2004 | 08:50 PM
Merlin's Avatar
Staff ALUMNI
Re: Oil-drain valve
Leaving the bottom cover off changes the aerodynamics of your car and lets all sorts of crap come up fron underneath.
Andrew, We Miss and Love You! Peace!
Old Feb 11, 2004 | 11:06 PM
wizawuza's Avatar
Re: Oil-drain valve
what about taking the bottom cover off, driving around for a minute or two, and then changing oil?
I've read that it's recommended that you change oil while car is still warm so that impurities don't settle to the bottom, and come out with the oil change.
And I don't want to go under the car and have to try to hurry to get the bottom cover off after I've come back from a quick "warm up" ride.
Then again, I have yet to remove the bottom cover so I don't know if it only takes like a minute anyways.. (not enough miles for 1st oil change yet)
Twlight blue/Willow 6mt.
It's here
