Best way to remove '07 spoiler?
Old Nov 5, 2007 | 01:50 PM
bearcat's Avatar
Hey guys, do any of you have any good tips on removing the OEM spoiler on an 07' Coupe? I've heard the horror stories about the glue but it seems that quite a few people have done it so I just wanted to see if there are any tips? Thanks in advance.
Old Nov 5, 2007 | 02:13 PM
chilibowl's Avatar
Heat gun (or blow drier) at the adhesion point, between the trunk lid and the spoiler. Start at the left, heat it up for about 1 minute, then with fishing line, slowly wedge it in between. Work youre way to the right until the spoiler is entirely off. Then heat up the glue, and remove with alcohol or Goo-Gone.
Old Nov 5, 2007 | 02:50 PM
bearcat's Avatar
Thanks for the quick reply. My guess is after this is off and cleaned, I can easily bolt and stick on an 05 spoiler. Is this correct???
Old Nov 5, 2007 | 02:54 PM
G35MC's Avatar
05 spoiler much better choice.
good luck removing.
Old Nov 5, 2007 | 02:55 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Good luck, I tried an gave up, I was too worried about having the paint come up with the spoiler.
Old Nov 5, 2007 | 03:05 PM
bearcat's Avatar
Did you heat it up good as well? I'm guessing it's not going to be like a knife through butter but surely if it's pretty warmed up the fishline would go through the adhesive. (I know, I'm trying to keep optomistic)
BTW, has there been more than one person here peel the paint off while trying to get the spoiler off? Otherwise, maybe it was just bad technique.
Old Nov 5, 2007 | 08:24 PM
Beebo's Avatar
No you have to drill new holes the bolt pattern is different
Old Nov 5, 2007 | 11:29 PM
marcellsr's Avatar
You can sell it to me after it's off, what color?
Old Nov 8, 2007 | 11:20 PM
bearcat's Avatar
It's Laser Red so you'd have to paint it. My new spoiler is on order so this one will come off probably sometime next week. Kinda expensive ($700) to go back to an older model spoiler, but I sure like the sporty look better than the classy look. Make me an offer
Old Nov 8, 2007 | 11:23 PM
patman530's Avatar
are you sure about this? from what i've heard, the 06+ and 03-05 oem spoilers have the same bolt patterns
Old Nov 8, 2007 | 11:44 PM
Beebo's Avatar
im sure...
Old Nov 8, 2007 | 11:56 PM
patman530's Avatar
im sure...
https://g35driver.com/forums/showthr...+03+spoiler+06
Old Nov 9, 2007 | 12:00 AM
Beebo's Avatar
damn i was told by my dealer and members on here that they were different... guess not.. sorry
Old Nov 9, 2007 | 12:10 AM
patman530's Avatar
its all good, i remembered this because i was thinking about doing the same swap
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dseet
Oct 11, 2015 12:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
