clear corner help!!!
Old Mar 3, 2004 | 05:01 PM
XIMER's Avatar
hey
im sorry to ask these newbie questions:
1. do you need to buy clear corners and light bulb to ge the clear look, or is just the clear corner enough?
2. where do you get them installed? dealer? mechanic?
3. how do you clear those think vertical lights?
thanks.
JHK 04' G35 CPE, PREM, NAV, SPASH, MOLDING
Old Mar 3, 2004 | 06:36 PM
damnz2z's Avatar
Re: clear corner help!!!
1. When you buy the clear corners, they come with orange bulbs so if you want to have the clear look then you need to buy 168 wedge bulb [color of you choice].
2. The clear corners just pop in and out. Look in you manual to see how to do it.
3. To change the bulb in the vertical light [clearance strip] you need to unsrcrew and take out pins in the front wheel well panels to get access to the bulbs. They are the same size bulb as the clear corners. There is a DIY if you need help in the DIY section.
Old Mar 3, 2004 | 06:40 PM
XCELR8's Avatar
Hope this helps:
1. Its looks best to install a clear bulb as well like the Piaa Xtreme Whites instead of leaving the orange ones. Looks pretty dumb having clear corners with orange bulbs.
2. Dont need to have them installed by a shop. They pop right out. Your owners manual tells you how to take them out. There should be instructions with the corners when you buy them as well.
3. The following link will tell you how to change the bulb in the vertical strip:
http://members.rogers.com/chrisg35c/g35lights.html
2003 BLK/BLK 6-spd Injen clear corners
Old Mar 3, 2004 | 06:51 PM
XIMER's Avatar
thanks so much!!!
Old Mar 3, 2004 | 06:58 PM
6MT_Coupe's Avatar
I read in a previous post that changing the orange bulb and putting in a clear bulb is a ticket waiting to happen... Not something a cop would pull you over for by itself, but if you get caught speeding or whatever, that is just one more ticket they can pile on the list...
That being said, when I finally get around to getting clear corners, I am definitely changing the bulb because I think it looks stupid otherwise. My 2 cents
Mods:
Aluminum racing pedals
JWT Pop Charger / Z-tube Combo
Old Mar 3, 2004 | 07:07 PM
XCELR8's Avatar
Cops here dont even know what Infiniti is let alone a G-35. If I get pulled over I'll just say thats how it came from the factory. hehe
Old Mar 3, 2004 | 07:16 PM
redwillow's Avatar
20 Year Member
<hr></blockquote> unless, of course, you have modified your corner lights with clear lenses to blink just like your turn signals.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
Old Mar 3, 2004 | 07:24 PM
XCELR8's Avatar
Cool! Have a DIY on that?
Old Mar 3, 2004 | 08:14 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I think someone mentioned that most law states that as long as the light does not project blue (some white lights are blue bulbs like PIAAs), does not flash white (i.e. clear corners that flash white) or seems brighter than the headlight, its ok.
This seems to be true in Hawaii as I have discussed this with some of my police friends.
You can mod your clear corners to flash, but as long as they flash amber and not white, esp. if located on the side of your car. (vs. front of your car)
Old Mar 3, 2004 | 08:16 PM
redwillow's Avatar
20 Year Member
<a href="http://forums.freshalloy.com/ubbthreads/showflat.php?Cat=&Board=UBB25&Number=67582745&page =&view=&sb=5&o=&fpart=all&vc=1">YES</a>
Old Mar 3, 2004 | 09:06 PM
XIMER's Avatar
can you just switch the bulb for the corner while your changing it to clear covers?
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
