Infiniti F'ed my car up...
Old Dec 28, 2007 | 04:58 PM
cungkpham's Avatar
you should demand them to fill up ur tank with JET FUEL!... not really. but yeah.
Old Dec 28, 2007 | 10:49 PM
TurK's Avatar
Yes because that would be very healthy for the car
Old Dec 29, 2007 | 06:01 PM
GEE-WIZ's Avatar
Now just wait for the asphalt to soften up on yor driveway. Are they going to pay to repave it?
Old Dec 29, 2007 | 06:44 PM
firefox's Avatar
You may be in a tough predicament. Does the fuel smell really, really bad or if it a little bad?
The reason I ask is this. I had a similar situation a few months ago where I had a serious fuel leak. The leak was coming out exactly where it is depicted in your pics. I took it to the dealer. Barely getting there as I'm pulling into the dealer my car dies as I leak a whole tankful of gas over a distance of 40 miles. BTW, it was a dumb idea to drive my car to the dealer in that situation, the car could have caught fire. It was a spur of the moment thing, the thought of my car on a wrecker just really pissed me off.
Now when they diagnosed it, they said that the quick connect (plastic connector) that connects to the fuel pump failed and they needed to order a new quick connect. In a nutshell the fuel was coming up a little through that hole under the rear seat where you access the fuel pump.
Keep in mind these folks did a fuel system flush a week beforehand so I was trying to place the blame of that service on the failure of the quick connect. However, that did not work, my car was out of warranty, and I was out a couple of hundred bucks.
In short, your leak may or may not be from the sending unit, we will see when you get it to the dealer. If it is, of course the dealer should fix it. If it is that quick connect to the fuel pump, then it may be another problem that was coincidental.
Either way, the interior of your car is going to smell like gas for a while. Which brings me to the point of my post, since I found this information to be key. I tried every kind of deodorizer to take out that gas smell. Nothing worked. Yes the smell got better and better after a week or so, but it didn't completely go away. However, surprising, somebody told me to put an open can of Folger's or some other coffee grind down in the back to soak up the gas smell. I did this for a week, changing out the grind every two days or so. The grinds would reek of the gas smell. So I knew it worked. Just wanted to share my 2 cents.
Old Dec 29, 2007 | 07:13 PM
1slowblackG35's Avatar
Man, my gauge just started last week not reading full, going just under the F. And now my pass window wont work with auto click anymore either. Hmmmm... coincidence? I think not!
Old Dec 29, 2007 | 07:56 PM
Pepper's Avatar
Well, I got my car back last night. They said that one of the mounting tabs cracked and caused the fuel to leak. I dont know if thats the truth or not but its fixed. They replaced the fuel tank according to the paperwork. I dropping the car back off to them on monday for a full detail. I told them that I wanted whoever is detailed the car to remove the back seat to clean underneath aswell (fuel smell originated from there). The window problem still isnt fixed but they said that they are going to call Infiniti Tech Support to find out what their next course of action is. I personally think that its the motor but they havent replaced it yet. As far as the fuel smell in the car... most of it is gone... But I hope that after the detail, it will be gone. (fingers crossed)
Old Dec 29, 2007 | 08:06 PM
Jason@Riverside's Avatar
You can always get INFINITI Consumer Affairs involved... They will tell your dealer what to do...
Infiniti Consumer Affairs
P.O. Box 685003
Franklin TN 37068-5003
800.662.6200
8:00 a.m. - 5:00 p.m. Eastern / Central Time / Pacific Time
Monday through Friday
Old Dec 29, 2007 | 08:08 PM
Pepper's Avatar
P.O. Box 685003
800.662.6200
Thanks for the info! We'll see what happens after Mondays detail...
Old Dec 29, 2007 | 08:14 PM
Glex25's Avatar
Administrator
Baking Soda works as well to get rid of the smell.
I heard a onion takes up that paint smell your car gets when it comes out of the bodyshop don't know how true it is just what i have heard
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Jul 27, 2015 05:25 AM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
