wtf happened to my car?
Old Mar 20, 2008 | 11:24 AM
LazyAlex's Avatar
i was driving last night..then all of a sudden..my clearance strip..lesene on my bumper...and u know when u turn ur headlights on..the lights on ur tail lights stay on..they alll dont work anymore...only my headlights and my brake lights when i brake works..also..u know that swtich u can move around to adj how dim/bright u want ur gagues to be..they doesnt work..it stayes on the brightest..and the light for my clock doesnt work anymore..anyone know wtf happened? or what i can check?
if not ima bring it into dealer..but does a cone filter w/ a MAF adaptor hooked up to the stock intake pipe void the infiniti protection plan thing?
Old Mar 20, 2008 | 11:26 AM
Hi-TechG35's Avatar
Any modification done to your car will void your warranty according to the "stealership". Check your fuses.
Old Mar 20, 2008 | 11:29 AM
LazyAlex's Avatar
i checked the fues..its fine..which i think im checkin the right one..the ones under the dash? or the ones near the battery?
Old Mar 20, 2008 | 11:30 AM
speedracerg35's Avatar
i would say you blew a fuse.
Hi-TechG35's Avatar
Check them both. i'm not sure which ones go where but check the diagrams for the fuses. My corner lights stopped working a while ago. I just left them alone.
Old Mar 20, 2008 | 01:30 PM
ibelonginprison's Avatar
Resident G35Driver Pirate
Check all the fuses that could be related. WITH A FUSE CHECKER. Sometimes fuses will not look blown, but still be bad.
Old Mar 20, 2008 | 05:11 PM
nutt's Avatar
wow all i can think of is the fuses but damn thats messed up
Old Mar 20, 2008 | 05:13 PM
BlueDevilBAMF's Avatar
Modifications only void your warranty if the cause of the problem can reasonably be attributed to the modification
Old Mar 20, 2008 | 05:43 PM
minh420's Avatar
it will be the fuse box hidden behind your battery
Old Mar 20, 2008 | 07:20 PM
Beebo's Avatar
^+1
Old Mar 20, 2008 | 07:36 PM
AGOG35's Avatar
Wow, this is interesting. Seems like something is going more crazy thatn a fuse. It could be a short somewhere. Maybe a wire pinch.
Old Mar 20, 2008 | 10:17 PM
Dude - if you still have your bumper to bumper warranty, get your azz to the stealership. If they try to tell you your mods caused this, kindly hand them a copy of the Magnuson-Moss Act, the interpretation of which says aftermarket parts (if they are to replace the "OEM" [Original Equipment Manufacturer - I will state here that I hate when people say OEM is Original Equipment Match, because that's incorrect as the acronym was originally used] part) do NOT void the warranty.
Bottom line, for warranty purposes, replacement is not a euphemism for modification. Modification would mean any aftermarket addition. You can change OEM parts with comparable parts without voiding a warranty. You just can't add parts (e.g. plenum spacer) and expect all of your warranty to be OK. However, I believe they still have the burden of proving that the added part caused the problem in order to not honor your warranty.
I'm not a legal expert but this is the interpretation of the law as I understand it.
Old Mar 21, 2008 | 12:03 AM
Beebo's Avatar
^+1
the dealer just cant say no... if they do... then they have to prove that the intake filter caused the problem... by law
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
rping
Jul 26, 2015 09:53 PM
ClwMike
Jul 23, 2015 12:55 PM
stay_tuned
Jul 21, 2015 07:09 PM
