Passenger Side Rattle?
Old May 23, 2008 | 12:07 AM
fishert16's Avatar
I have some sort of rattle coming from the passenger seat and sounds like it is coming from the seat belt area. It does not do it (or not nearly as bad) with a passenger riding. It only does it on a rough road or small bumps. I used the search function and the most common place is the seat belt but when driving I tried holding the seat belt and it was still doing it. Does any one have any advice? Thanks
Old May 23, 2008 | 12:17 AM
sansin's Avatar
i've had rattling in the area as well.... sometimes it's the seat belt. easy fix is to adjust the passenger seat forwards or back a little to let the belt hang. other times the rattle is actually coming from the rear quarter panel. took it to the dealer; took a tech for a test drive... found the rattle and fixed it (free of charge). they pulled the panel off and put foam behind it to stop it. seems to have worked. no more rattles.
Old May 23, 2008 | 12:18 AM
sansin's Avatar
Old May 23, 2008 | 12:29 AM
fishert16's Avatar
Well it could be the rear quarter panel but that would not explain why it does not do it when there is a passenger riding. Any other thoughts?
Old May 23, 2008 | 10:08 AM
SukaZenki's Avatar
Fish, it might help if you put the year and model of your car. Create a signature so that in future posts for any problems, people might be able to help you better. Some problems are related to the year and model of the car. If it's the rear quarter panel, there's a TSB for that. If you think it's coming from the passenger side; I'd check all around the passenger seat. Check the bolts holding the seat for tightness. Take the passenger seat belt; isolate it by securing it to the passenger seat without a passenger then drive around to and listen to if you still hear the rattle. Good luck.
Old May 23, 2008 | 11:10 AM
fishert16's Avatar
I have saved my sig now, what year was the TSB for the quarter panel on? Also I am leaning towards the seatbelt, but I will give some insight as I isolate it today. Thanks
Old May 23, 2008 | 10:40 PM
thibodeaux619's Avatar
I havent seen this problem yet, but it may be because i dont let women over 300lbs ride in the G. Tighten all your bolts and you should be fine. And no more big girls fish
Old May 23, 2008 | 10:48 PM
fishert16's Avatar
HaHa only your girl Stacy has been up there! And you need to settle down on the coming soon in your sig because soon is becoming much later!
Old May 24, 2008 | 01:17 PM
Blue Lion's Avatar
My 07 coupe passenger door speaker cover rattles. It only happens on rough blacktop, smooth pavement is fine. I don't know if this is your issue also. The noise on mine stops when you apply light pressure on the cover, pushing toward the outside of the car.
Old May 24, 2008 | 11:29 PM
badmilk's Avatar
i notice a slight passenger side rattle sometimes as well. prolly happens like 3% of the time i drive so it is pretty rare.
Old May 25, 2008 | 02:17 AM
Kensi's Avatar
could be ur glove box =)
mbe093
Lights
Oct 2, 2016 11:09 PM
brane123
Interior
Aug 23, 2015 06:55 AM
wylin
Lights
Jul 18, 2015 06:12 PM
