g35 coupe gas problem or not?
Old May 30, 2008 | 09:53 AM
specialist's Avatar
My gas light just when on so i filled it up i only got 45 liters in the car. That only converts to 11.7 gallons. then the gas pump clicks and i can't fill any more.
Is the problem still the sensor needs to be cleaned? then i will be able to put a full 20 gallons? since you said that a g35 coupe takes 20 gallons
Old May 30, 2008 | 09:55 AM
g35panama's Avatar
i have the exact friggin problem, its driving me crazy, im ordering both sending units from infinitipartsusa.com at about 60$ each
Old Jun 2, 2008 | 10:02 AM
specialist's Avatar
Today i got 52 liters in my car. what the hell is this? almost 75 liters but not quite there yet.
Old Jun 2, 2008 | 06:40 PM
silverg35guy's Avatar
There are some pictures here borrowed from DIY thread on fuel pump install, can you point where the q-tip'ing of the floaters go?
https://g35driver.com/forums/engine-drivetrain-forced-induction/190372-walbro-255-installation-diy.html
Old Jun 11, 2008 | 08:19 AM
specialist's Avatar
I took out the one side on the pasenger side and took out the whole unit and it was clean
Old Jun 12, 2008 | 01:24 AM
oxfordtemple's Avatar
I 'm one of g35 owners group in Hong Kong. Most of our member have the same problem on these too. The solution is driving your car a short distance (less than 1mile) after u filling up 3/4, then you go back to gas station and now you can re-filling up to full tank. You will probably see the guage needle pointing to full. Try it, its really work.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
