Noise when you turn off the car
Old Jul 13, 2008 | 02:26 AM
IP35's Avatar
each time i turn off the car it should like something is lose? make a noise for a sec after i turn off the car. Could it be the timing chain just coming to a stop?
Old Jul 13, 2008 | 02:34 AM
twitch's Avatar
I also get a somewhat loud rattle type sound when I shut the car off. Initially I thought is sounded like the exhaust vibrating or something but I'm not certain what it is. I've come to accept it as "normal".
I do remember coming across a thread where someone mentioned it was the transmission or the clutch if I remember correctly. Try turning the car off with the clutch depressed and then without it and see if it makes a difference. I haven't tried this because I don't get the noise everytime I turn the car off.
-edit- Here is the thread I was referring to
https://g35driver.com/forums/showthr...ferrerid=32434
Old Jul 13, 2008 | 03:04 AM
ShanesG's Avatar
subscribed, my aunts car does the same thing it make a loud wistle sound for a couple seconds after she turns the car off...
Old Jul 13, 2008 | 01:24 PM
vr6pwrdgti's Avatar
I have the same thing but from what I read on the forums it happens to alot of people and even the dealer says the chatter noise is normal. If you press on the clutch pedal you wont hear the noise.
Old Jul 13, 2008 | 02:11 PM
shilohap's Avatar
I hear that noise too! But it's usually my wife!
Old Jul 13, 2008 | 02:14 PM
Xet's Avatar
Xet
i hear it too.. it sounds exactly like when you accidentally stall the car to me so i figured it was a bit weird but normal
Old Jul 13, 2008 | 03:25 PM
IP35's Avatar
hahahaha, no fix for this...
Alright, it looks like it's the clutch chatter. I had the clutch engaged and turned off the car...and no noise.
Thanks for the help all
Old Jul 14, 2008 | 01:02 AM
haywordvq35's Avatar
+1111
Old Jul 14, 2008 | 07:57 PM
sevret.t's Avatar
yes its the clutch, i turned off the car with and without the clutch engaged and when the clutch is in it doesnt make any noise
Old Jul 15, 2008 | 12:28 AM
htownboy's Avatar
Shut down with clutch engaged; no noise!
Old Jul 15, 2008 | 12:43 AM
BlueDevilBAMF's Avatar
It's the throwout bearing making noise... perfectly normal
Old Jul 15, 2008 | 12:45 AM
ndlive's Avatar
yea it's normal.. what i do is i just press the clutch, shut the car off, then put it in 1st/reverse and get out.
no noise this way... it's almost second-nature for me now lol
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
rping
Jul 26, 2015 09:53 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
Thaaa_king
Jul 18, 2015 05:56 PM
