HELP ME,CLUTCH JITTERS AND VIBRATION :(
Old Apr 29, 2004 | 05:37 PM
COMBUSTION's Avatar
Hi everybody im new here, just got my baby Tuesday white g35 coupe with black interior. What a beauty … but im kind of disappointed with the clutch feel, the day I drove out of the dealer I felt a jitter, notchy, vibrating feeling, like the clutch was not catching correctly olny in first(feels like its warped), you can also here somewhat like a scraping noise most of the time when im at a light when engaging in first gear and taking off. Now im not taking off hard or anything like that or abusing the car, it only has a 160 miles on it. I called Infiniti and they said to break it in… im worried about this, I just got out of my bmw 330 which was a stick and man was it smooooth. Is this normal for the g35s tranny? Should I be worried? Should I get another opinion? Did any of you have a similar feeling or problem? Please any post would be greatly appreciated. sorry for the long post.
Old Apr 30, 2004 | 09:27 AM
Daniel_G's Avatar
Re: HELP ME,CLUTCH JITTERS AND VIBRATION :(
Yes, this clutch has some chatter. It also doesn't help that it comes from the factory with a high engagement(at least mine did). I adjusted my clutch pedal using 3 1/2 full turns and made a huge improvement.
Old Apr 30, 2004 | 06:40 PM
wrexxy's Avatar
i have the same problem with mine. the grinding noise doesn't happen all the time, but when it does it's in first at a take off or a stand still...
BUMP! (for more replies )
Old Apr 30, 2004 | 07:28 PM
cynicaL102's Avatar
when i first picked up my g i thought something was wrong with it as well. i think the car takes a bit of getting used to. my clutch never felt weird besides the fact that it was high and catches high, but i thought the shifter was strange for vibrating so much. if it grinds, you should get it checked out. my car never grinded switching gears.
[ 2004 G35 coupe ] - | 6MT | Black/Graphite | Premium |
Old May 1, 2004 | 03:47 AM
accordfreak's Avatar
i hate the fact that the shifter vibrates so much. the 330 doesn't vibrate at all.
Old May 1, 2004 | 01:18 PM
COMBUSTION's Avatar
allways in first it jitters and chug chug chug and the rest of the gears r all smooth, it gets on my nerves argggg. thnks for all the post guys
Old May 1, 2004 | 07:07 PM
Profile4's Avatar
i have the smae problem...do any of you guys hear the slight rattling noise when you are in neutral and the clutch is not depressed? i hear this sound more often than not, especially after a long drive, and the only time i've ever heard this noise was due to a worn main throwout bearing, which scares me since this car is brand new...i get alot of the chatter too which is often related to the throwout bearing as well, i'm going to notify the dealer when i get my next oil change in about 500 miles, hopefully this is normal, but the sound is really annoying and kinda makes the car sound cheap as i take off from a dead stop. it's true that you cant hear the noise when u have the a/c on or the radio, but with the windows down you can hear wat everyone else hears outside of the car. it's kinda embarassing when u have ppl look at your fine car then they hear the rattling and chattering from the car when u take off =(
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
