Tranny & Rear Differential Fluids
Old Nov 26, 2008 | 11:27 AM
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by Mikalvelix17
Amsoil MTG 75W-90 API GL-4 for the transmission and Sever Gear 75W-90 API GL-5 for the rear differential
Originally Posted by Slick 6MT
I'm about to change out the tranny and rear diff fluids in my car.
These are the products to use?
Yup...that's what Amsoil I'm using and very happy.
Old Nov 28, 2008 | 05:18 PM
dubel's Avatar
The dealership said I need the differential additive but I don't see it recommended on the Amsoil site. Do I need it? 06 coupe mt
Old Nov 28, 2008 | 06:56 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
.. i was looking at flushing out my tranny & diff. fluids with Amsoil MTG 75W-90 API GL-4 for the transmission and Sever Gear 75W-90 API GL-5 for the rear differential. is this recommended and will this make a big difference in terms of smoother shifting? any info will help. thanks
Why not MTF 5W-30????
It's designed for synchromesh trannies.
:edit:
NM... I see MTG is the spec viscosity & also designed for synchro trannies.
Old Nov 28, 2008 | 08:04 PM
smoovarrowhead's Avatar
Redline fluid seemed to help cold shifts a bit. Smells like hell tho
Old Nov 28, 2008 | 09:56 PM
bythabay's Avatar
The dealership is "confused." Service manual specifies any API GL-5 75w90 or 80w90 gear oil. Go with Amsoil SVG 75w90
Old Nov 29, 2008 | 08:08 AM
6MT Coupe
Agree dealer confused (what else is new lol) Diff does NOT need friction modifier additive.
Friend of mine runs that in his Z, seems happy with it.
Old Nov 29, 2008 | 11:54 AM
I remember reading somewhere Infiniti puts friction modifier in the differential fluid when brand new to assist break-in. Thereafter it is not required. Just make sure you have the correct APL rating. This goes for all Nissans.
Old Nov 29, 2008 | 12:11 PM
Swivel's Avatar
Moderator
:edit:
Yup, MTGQT Manual Transmission & Transaxle Gear Lube 75W-90 for the transmission, Severe Gear 75W-90 for the diff.
Old Nov 29, 2008 | 12:59 PM
nath75's Avatar
Going to AMSOIL this week...
Still can't do the oil though - in the middle of OC test #3. I WILL DEFEAT THEM!
Old Dec 31, 2008 | 03:00 PM
maciejk's Avatar
i put a differential fluid additive which i think was AMSOIL into my LSD on my 89 supra and it helped with chatter, i don't know if its good to put it in my VLSD on my sedan since it dosen't have clutches but some silicone mechanism instead, my diff isn't chattering but i'd like to keep it running better
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Blakearold
Aug 19, 2015 10:20 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
underworld
Aug 6, 2015 01:36 PM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
