Cigarette Ligther doesnt give power?
Old Sep 14, 2008 | 02:13 AM
Xet's Avatar
Xet
I'm trying to use my cigarette lighter to power my radar detector for my trip to school tomorrow because the center console one is used for the fm transmitter. But I cant get the lighter to power either, does this car just not have power hookup to it? Is there any other place to plug in which I have missed??
Old Sep 14, 2008 | 02:22 AM
neight's Avatar
ur right it doesn't give power, and i dont think there is any other spot. you might be able to get a 1 into 2 adapter tho... maybe.
Old Sep 14, 2008 | 02:42 PM
eah026000's Avatar
my 07 gives power from lighter port.... have to twist plug so it contacts the right location, but I get power from it... Maybe new after '05?
Old Sep 15, 2008 | 06:15 PM
Blue Lion's Avatar
I had this happen on my Jeep recently and it was a blown fuse. One outlet worked for every item, the other didn't.
Old Sep 15, 2008 | 06:17 PM
gotspeed81's Avatar
it just might be a blown fuse. it should work
Old Sep 15, 2008 | 10:22 PM
tdm racer's Avatar
If you're shoving all kinds of different adapters into the sockets, sometimes they will short out and blow a fuse, check your fuse box. it's usually a blue 15a fuse which blows out on your accesories. Change it, then retest, your power supply should work ok. Or if it's the charger causing the problem, it could blow the fuse again....
Old Sep 16, 2008 | 02:29 PM
Xet's Avatar
Xet
thanks guys. i found it strange that a new car wouldnt give power. ill check the fuses out.
Old Sep 16, 2008 | 07:13 PM
akk08's Avatar
its a fuse.
Old Nov 8, 2008 | 08:41 PM
jayflyxx's Avatar
same with my 05 x. are the front (under radio) and center (under armrest) on a different fuse?
Old Nov 8, 2008 | 09:13 PM
silverg35sport's Avatar
is the power on your car turned on?
If not then it wont give any power.
zcherub
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
