Need help killing cluster rattle----Pic inside
Old Nov 11, 2008 | 04:57 PM
Bigd2k6's Avatar
like the title says. stock photo enclosed to show location. i've already wedged velcro (the soft side) and 3M tape which helped some but it's still there on really bumpy roads. i think it's making contact further in (toward the rear of the car). if i pry anymore to get deeper in there, i think i may crack the plastic. only solution would be to take off the top cover and apply 3M to the whole underside of the cover. i've already looked at the service manual but it just shows how to take the cluster itself from the trim and remove the mirror adjustment switch. plz halp guys!!
Attached Thumbnails Need help killing cluster rattle----Pic inside-img_1284.jpg
Old Nov 11, 2008 | 05:21 PM
JOEYD0730's Avatar
does it sound like thee is a bb rolling around in your cluster? mine comes and goes...
Old Nov 11, 2008 | 08:55 PM
Bigd2k6's Avatar
no, it's just tapping. if i wedge my finger in between the dash and cluster, it goes away.
Old Nov 12, 2008 | 12:48 AM
tango5o4's Avatar
i have the same problem.. let me know if you come up with an alternative solution! GL man
Old Nov 12, 2008 | 07:48 AM
vhtran's Avatar
hahaha same here on my 04, pissed me off sometimes. Let me know if anyone able to fix it.
Old Nov 12, 2008 | 11:40 AM
Darkstar752's Avatar
Why don't you wedge a piece of foam in there or something?
Old Nov 12, 2008 | 11:42 AM
fbpem1's Avatar
it moves up in down with the column, you need to take the cluster out and reinstall the felt tape that should be there from the factory. simple as that,
Old Nov 12, 2008 | 12:35 PM
vhtran's Avatar
I have took a lot of parts off/on the car, but never on the cluster, how simple is it?
Old Nov 12, 2008 | 02:38 PM
https://g35driver.com/forums/body-in...56k-ha-no.html
Here you guys go. I believe this is for an '04 model, I don't know if it changed for the new gauges in 05.
Old Nov 12, 2008 | 02:44 PM
vhtran's Avatar
thank you
Old Nov 13, 2008 | 05:42 PM
Bigd2k6's Avatar
you rock. when i fix the rattle, i will definitely post up pics for a more thorough DIY.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
vQFamily
Sep 30, 2015 01:17 PM
wow600rr
Sep 28, 2015 11:50 AM
Blindside360
Sep 18, 2015 09:00 PM
