An odd smell...
Old Nov 19, 2008 | 08:04 AM
03stage2's Avatar
Question An odd smell...
Since it has started to snow up here I have been noticing an odd smell coming from my G. It almost smells like burning rubber or radiator fluid. I cant see any leaks on my garage floor. I did check the coolant level and it was barely below the minumum mark. I did add some to get it over the minimum mark. Should you check the coolant levels when the engine is cold or will it make a difference? Im curious if the smell is just salt and grime building up and burning off under the car? Anyone else experience a smell once the snow arrives?
05 AT coupe
Old Nov 19, 2008 | 09:09 AM
GreenGoblin's Avatar
The goblin resurrection
are u sure it isnt the heater making the smell?
Old Nov 19, 2008 | 09:11 AM
03stage2's Avatar
Positive, it is a distinct burning smell that is more predominate when I open up the hood...
Old Nov 19, 2008 | 09:20 AM
fluffy's Avatar
checking the belts?
Old Nov 19, 2008 | 09:21 AM
vhtran's Avatar
Few times I got funny smells from the heater, almost like burning cheese. Only few times, not anymore.
Old Nov 19, 2008 | 10:29 AM
xXHotelCrazyXx's Avatar
Has your VDC been keeping itself busy? Coming on alot?
Old Nov 19, 2008 | 03:59 PM
odncr's Avatar
Coolant/antifreeze has a sweet smell. Be very careful when handling it. A tablespoon can kill an adult human if ingested.
As far as checking the coolant level you have to open up the radiator cap. The level you just described is the overflow tank. Once you open up the radiator cap the true level of your coolant can be seen. A full level is if the fluid is an inch below the snout of the cap. Make sure to check the coolant level when the car is cold.
NEVER OPEN THE RADIATOR CAP WHEN THE CAR IS HOT. YOU WILL BURN YOURSELF.
Old Nov 19, 2008 | 07:43 PM
smoovarrowhead's Avatar
Whats up HotelCrazy from 6mt. Stage2 check for your hoses touching the timing chain cover up front. This area seems to get the hottest and the hose clearance is minimal. I did notice a slight propane type smell when hot after switching to Redline diff. & tranny fluid.
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
Tyler's03G
Aug 13, 2015 10:04 AM
Rehman2009
Jul 27, 2015 03:23 AM
