headlight fails to turn on sometimes?????
Old Dec 5, 2008 | 08:03 PM
elpibe's Avatar
one of my headlights fails to turn on when i start the car but after tuning the lights off and then on a few times it works; after a few tries. I think there is a problem with the connection but i really have no idea. What do you think?
Old Dec 5, 2008 | 08:15 PM
Solekeeper's Avatar
Are they modded at all?
BolivianFuego's Avatar
This was happening to me, the ignitor on the bulb was loose, i needed to turn it to the right and lock it in place.
After i did this, all the flickering and the bulb turning off went away.
Old Dec 5, 2008 | 08:33 PM
CreativeDesignZ's Avatar
sounds like ur ballast is on its way out
Old Dec 5, 2008 | 08:34 PM
elpibe's Avatar
yea i thought it was something like that.
Old Dec 5, 2008 | 08:36 PM
Darkstar752's Avatar
Check your ignitior first, just make sure it's tight. If that doesn't work, take out the ballast and open it. I've seen ballasts badly damaged from water, if that's the case, seal the other with silicone and buy a new ballast for the broken one.
Old Dec 5, 2008 | 08:39 PM
elpibe's Avatar
what exactly is the igniter?
Old Dec 5, 2008 | 09:13 PM
Beebo's Avatar
I had that problem for a few months then it just went away... i really have no idea what was wrong
Old Dec 5, 2008 | 09:35 PM
Its the connector that is plugged to the headlight, take out your wheel, and peel back the inner plastic fender lining, and check the headlight. Turn it to the right when you remove the plastic cover, i bet you thats it.
Nickles
Sep 1, 2015 08:11 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
Mick_L
Aug 25, 2015 04:27 PM
attarday
Jul 15, 2015 04:03 PM
