rev matching while up shifting. Pls Help.
Old Dec 9, 2008 | 10:17 AM
Darkstar752's Avatar
All years have DBW
Old Dec 9, 2008 | 10:58 AM
viceversa's Avatar
I always thought this was due to the weight of the stock flywheel.
Old Dec 9, 2008 | 11:18 AM
yourdoinitwrong's Avatar
That very well could be the cause on some makes of cars. Without someone knowing definitively if there is programming in the G to make the revs hang for emissions reasons, we will just keep guessing.
Old Dec 9, 2008 | 12:17 PM
viceversa's Avatar
A friend of mine has a civic SI and the rev hang on that car was ridiculous. Apparently there is a service bulletin out to fix that issue on the car. And it is also fixed with a re-flash called the hondata.
Can anyone with a re-flash or tune chime in about the rev hang on their car?
Old Dec 9, 2008 | 12:24 PM
mIKE's Avatar
It's partially rev-hang and partially the (very) heavy flywheel.
Old Dec 9, 2008 | 01:05 PM
sonsofliberty's Avatar
hondata is only for hondas
Old Dec 9, 2008 | 01:32 PM
viceversa's Avatar
^ lol i know this. I was simply referring that the rev-hang issues on the civic SI's (which are also DBW) could be fixed by re-flash. Wondering if a re-flash or tune can be done with our cars to reduce the rev hang.
Old Dec 10, 2008 | 03:45 PM
ONLYG35's Avatar
i personally think its the flywheel. i just got a jwt flywheel with stock clutch, pressure plate, and throwout bearinsg. i notice it is way easier to drive. it was hard to hit 2nd gear smoothly before, which i chalked up to the heavy stock flywheel... it is much easier to drive smooth now.
of courswe there is a msall amount of noise below 2000 due to the LWFW
Old Dec 13, 2008 | 04:16 PM
btjeep3's Avatar
Thanks to everyone for replying. It sounds like a lot of other people are having similar experiences. (I'm glad it's not just me). I hope that there is a flash/re-programming available soon... Or something of the sort to make it a little more sport-driver friendly. I haven't looked into the grounding kits yet, but I will.
Thanks again,
BT
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
mbe32
Nov 13, 2015 11:09 PM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
