mrev2, plenum spacer, and pop charger
Old Dec 17, 2008 | 08:36 PM
EnerOnE's Avatar
The title says it all. I've search but I can't find anything. Has anyone tried this set up on a rev up? Ive read that the pop charger lets in too much cold air for the mrev2 spacer combo but has anyone tried it? Is it a noticeable difference??
Old Dec 17, 2008 | 08:39 PM
Beebo's Avatar
i have it all on my rev-up... im very happy... nice gain... the car pulls alot harder
sucking in to much air?
not to be rude but if you have searched you suck at it haha
Old Dec 17, 2008 | 08:58 PM
EnerOnE's Avatar
haha i guess i do, i just wanted to be one of them noobs to start up his own post. Beebo if you don't mind, what did you have on first? I have the mrev2 + spacer and i'm afraid of losing power with the pop charger. I have read and heard two different things so i want hear from someone who has done it.
Well, I'm going to do it anyway, I just ordered a pop charger but wanted to hear something comforting before in arrived and I install it.
Old Dec 18, 2008 | 12:43 AM
eurodre's Avatar
just run a cold air intake and u wont have the problems that pop chargers do
Old Dec 18, 2008 | 01:09 AM
Xet's Avatar
Xet
^but then you have the problems that come along with a cai lol
Old Dec 18, 2008 | 01:40 AM
eurodre's Avatar
yah but ull have problems with EVERYTHING, thats not the way to look at it, almost every mod u can have problems wiht it, doesnt mean u avoid it, but id get a cai over a popcharger ANYDAY cus at least ur getting something worth while
Old Dec 18, 2008 | 09:52 AM
fishhouse's Avatar
i've installed Pop Charger type intakes in my last couple of cars (JWT on this 07 Coupe and a Injen on my previous Nissan Maxima) - in both i had noticeable lose in low-end, off the line grunt. the powerband seems to shift - felt like less torque on the low end and more at higher RPM (around 3000+).
you'll likely notice the same - perhaps the MREV and spacer will offset a bit. i'm getting ready to add a 5/16 spacer to mine in hopes of this.
Old Dec 18, 2008 | 10:33 AM
gary c's Avatar
Best Bang or your $
Anyone that has a '05+ with a Revup motor would be stupid NOT to install the
MotorDyne additives you have listed. Tony guarantees no less than 15 RWHP
and 18 lb-ft torque plus more with other mods like cat-back exhaust and
intake. This is the "Best Bang for your Buck!" Motordynes # 661-993-5111
Gary
Old Dec 18, 2008 | 01:39 PM
Beebo's Avatar
Originally Posted by gary c
Anyone that has a '06+ with a Revup motor would be stupid NOT to install the
Gary
Dont you mean 05+?
Old Dec 18, 2008 | 06:31 PM
erklep's Avatar
Originally Posted by kidtronix
I too am ready for these rev-up mods. My primary question is this right now:
The copper throttle body gasket has a water line that runs on it, yet I see no valve in the photo depicting the set up. What gives?
the copper gasket is to heat up your throttle body in colder temps. my setup came with a small valve to turn the flow on or off. any water valve should work.
Old Dec 18, 2008 | 07:04 PM
EnerOnE's Avatar
Yes I have the mrev2 + plenum combo and yes it does make a difference i am very pleased with it. I have read that adding an intake will lessen my gains. I guess I'll find out when i install it. I'll let you guys know. Oh, the reason I am getting the pop charger is so I can get the relentless strut bar to fit
Old Dec 18, 2008 | 08:44 PM
Beebo's Avatar
I had the pop charger 1st, then spacer then Merv2
Picture Share
Feb 4, 2018 12:41 PM
AL8782
Oct 3, 2015 10:26 AM
w4kj4k
Oct 2, 2015 07:57 PM
dcsbh1
Oct 1, 2015 03:15 PM
