Clock wont light up???
Old Jan 11, 2009 | 07:36 PM
elpibe's Avatar
I bought an 03 coupe and the clock does not light up. replaced the bulbs and it still fails to light up. What could be causing this? blown fuse? wiring problems? let me know what you think.
Old Jan 11, 2009 | 09:05 PM
uf20wop's Avatar
fuse maybe
Old Jan 11, 2009 | 09:20 PM
Hi-TechG35's Avatar
Either fuses or you may be getting the wrong size bulb.
Old Jan 11, 2009 | 10:32 PM
Furious Vegas's Avatar
I've been looking at my clock too.
Are there supposed to be lights on both sides? It seems like only the left side of mine lights up, but you can still read it in the dark. Doesn't seem right to me.
Old Jan 11, 2009 | 11:34 PM
04GREYGHOST's Avatar
I have the same question as this guy about whether or not there are bulbs on both sides. Also, how many bulbs are in the clock? Mine seems to light only on the right side and is dim.
Paula
Old Jan 11, 2009 | 11:38 PM
darren03's Avatar
There are bulbs on both sides..2 bulbs in total
Old Jan 12, 2009 | 09:20 AM
vhtran's Avatar
Somtimes I bang it a little and comes right back on.
Old Jan 12, 2009 | 09:30 AM
Hi-TechG35's Avatar
^hahahah ahhhh banging is the key sometimes...lol
Old Jan 12, 2009 | 11:48 AM
darren03's Avatar
I think if your car is still under warranty they will replace the bulbs for you. I changed the bulbs in mine to brighter ones when one of them went out. It is a pain to get the dash trim off from around the clock display though....
Old Jan 12, 2009 | 11:51 AM
elpibe's Avatar
what kind of bulbs did you get? where did you get them?
Old Jan 12, 2009 | 12:00 PM
darren03's Avatar
I got them from http://autolumination.com/74.htm there about half way down the page. There called Neo-wedge bulbs type B. I see they have LEDs also now..
Old Jan 12, 2009 | 12:09 PM
elpibe's Avatar
if i want stock ones do i have to buy them from the dealership?
Old Jan 12, 2009 | 12:11 PM
darren03's Avatar
Is your car under warranty? If so they will replace them<---from what I've heard.
Old Jan 12, 2009 | 10:42 PM
bocatrip's Avatar
For what it's worth, there was a TSB for the early clocks. I believe it had to do with not being bright enough and not being able to read the time easily due to the very thin arms.
Old Jan 14, 2009 | 10:26 AM
darren03's Avatar
With the bulbs that I got you can see the clock no problem..
Mry
Mar 3, 2023 01:03 AM
wonderizm
Sep 24, 2015 03:09 AM
flytim3
Sep 5, 2015 01:23 PM
underworld
Aug 6, 2015 01:36 PM
