Tire sizes
Old Jan 16, 2009 | 12:45 PM
kleinr's Avatar
Tire sizes
i have an 04 G and I was wondering if a 235/45/18 would fit on the front as opposed to the OEM 225/45/18
Old Jan 16, 2009 | 12:53 PM
vhtran's Avatar
I got 245/35/20 and fit perfectly, you're fine
Old Jan 16, 2009 | 12:55 PM
kleinr's Avatar
are those on the front or back?
i'm worried about em rubbing when i turn
Old Jan 16, 2009 | 01:00 PM
vhtran's Avatar
those are fronts, my rears are 275/30/20
Old Jan 16, 2009 | 01:29 PM
gary c's Avatar
He has OEM 18s they're 8" wide! Not 19s or 20s....?
Since you have the '04 OEM wheels you can use/run 245/45X18 both back
and front, that makes a very stable combo without any issues of rubbing. I
really disliked have 225s on my front end....
Gary
Old Jan 16, 2009 | 01:34 PM
vhtran's Avatar
You can go up by 10, 225 to 235 is fine.
Old Jan 16, 2009 | 01:55 PM
avs007's Avatar
Gary
You can mess up your VDC doing that, if you upset the standard stagger. I did that on my car, and the VDC kept kicking in braking the front left tire when I took mild curves, causing the tail to kick out.
Old Jan 16, 2009 | 01:56 PM
avs007's Avatar
245/40-18 will work better, as it's closer to the stock rolling size. That's what I'm running right now on my fronts.
Old Jan 16, 2009 | 01:59 PM
LjN_728's Avatar
You're riding on 20's, the OP has 18".
Old Jan 16, 2009 | 02:49 PM
echang0501's Avatar
i have a question. Can i go 235/45/17 and225/45/17 instead of 50" aspect ratio? im tryin to get some winter tires. Please help
Old Jan 16, 2009 | 02:53 PM
vhtran's Avatar
Here's on my winter setup, with OEM 18" I have the same spec except its winter tires. LOL
Old Jan 16, 2009 | 02:55 PM
officerdbag's Avatar
Ok, I was gonna say.. 275's on stock 18's?? Are you ****ting me? lol
Old Jan 16, 2009 | 03:04 PM
echang0501's Avatar
oh really??? ok i feel good now. cause you seem like you know what your doing.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
