Help, I need to know all the problems with my G35C to fix before warranty expires...
Old Feb 23, 2009 | 10:03 PM
LaConic2's Avatar
i say, just go thru all the basic stuff, check to make sure things are functional.
try to see if theres any funny noises or other odd things...
since were on this thread...
on my car:
i hear a hum.on the front right, same with my 17s n 20s...worse with the 20s..at 20-40mph...i hear it more and more now..
wheel bearing? is that covered too?
Old Feb 24, 2009 | 02:34 AM
tt88supraman's Avatar
Originally Posted by Ben_G35
yup if they do the inspection and find a problem they will and the problem is covered by warranty then everything should be FREE! but if you do the inspection and nothing is wrong or the problem is not covered by warrenty you will get charged for the inspection. but if you come with a certian problem like "my rear axle is clicking" they will check it and lube it up. no charge. like i had a problem (well still do) with my engine making a ticking noise sometimes, i went there and told them that and they lubed my axle saying it might be the axle, didnt fix the problem, i came back twice after that and of course the car doesnt make any noise when your at the dealership!! and they still to this day cant figure out the problem and i've been there like 3 times with no charge.
at least i got a free car wash out it! and they vacumed my car
i took my car in today cuz i wanted couple things fixed. i asked the service guy if i can get a 160 point inspection and he told me 2 get a pre owned vehicle inspection which was 128 bucks. was he trying to make some quick bucks off of me? my warranty ends at april.
Old Feb 24, 2009 | 02:47 AM
05_G35Drvr's Avatar
For the 160 point inspection, they will charge you for inspecting the car because you are not bringing back the car for a "sound that you are hearing". The way they look at it is that if its nothing wrong with the car, they are actually losing out since Infiniti won't compensate for the charges like they do when something is fixed by warranty.
As for the clicking sound, I know that I have searched high and low all over the thread to see if anyone had suggestions and what most people would tell me is that it was the axle that needed lube. Not too sure if you guys are having the same problem but I would hear it whenever I would drive on a bumpy road with the windows rolled down, well they FINALLY found the problem after 4 or five visits of going from Infiniti or the dealership that I bought the car from that replaced the brakes before I bought it. The Service manager checked my car and said that first of all, on order to avoid the clicking sound, you must purchase the performance brake pads from Infiniti, which the other dealership did not. Also the Brake Hardware needed to be lubricated thoroughly. Also the one thing they told me that was making alot of the noise is the fact that my Emergency brake was a little loose and they just tightened it and the clicking went away. Thankfully the dealership payed Infiniti for the brake job, and Infiniti also brought the price down 50% from its original price.
Old Feb 24, 2009 | 03:12 AM
lovemyg88's Avatar
the best way is to tell them to check a random part. Like me, i hear noise coming from the front, but some guys in this forum who have the same problem told me that it's from the rear axle. So i'll have my car checked for the rear axle. Just making things up, to have the dealer check the car. But usually, the dealer will check for other parts as well. Not a full inspection, but at least you can have some other parts inspected and if that part is going bad; and still under the warranty, you can have it fixed also. And as always, you can have your car washed and vaccumed free.
Old Feb 24, 2009 | 10:37 AM
eurodre's Avatar
https://g35driver.com/forums/brakes-...uspension.html
Old May 20, 2009 | 10:49 PM
UberDriver88's Avatar
This post is kinda dead, but I am still under my basic warranty and wondering if I can bring it to a Nissan Dealership for the work and service, I think I need new brakes and some other stuff. The nearest Infiniti dealership is 30 min away. Would you recommend going to a Nissan dealership for service.
Old May 20, 2009 | 11:29 PM
eurodre's Avatar
brakes will not be covered under the warranty, it's a wear and tare item
Old May 21, 2009 | 08:38 AM
Thanks for answering about 5% of the question I just asked...I know, I read the warranty information booklet btw. I plan on having them just inspect the car.
Old May 21, 2009 | 10:14 AM
eurodre's Avatar
geez don't get an atitude if i gave you an answer to only what i was certain about..
RA081024
Aug 18, 2015 07:03 AM
Team STILLEN
Aug 10, 2015 08:17 PM
chinee
Aug 8, 2015 10:11 AM
sailfish250
Jul 30, 2015 11:39 AM
slider_ua
Jul 29, 2015 04:17 PM
