bottomed out..help
Old Apr 11, 2009 | 05:42 AM
2fast's Avatar
bottomed out..help
hey guys, well my car is in panama now.. ive bottomed out a few times(basically my back end scraping the ground.. usually because of stupid hills or some really big speed bumps they have here..
Ive also had the middle bottom scrape a few times..
should i be worried? i dont see any leaks or anything..
ALSO
I just drove 1hr on this super bad road.. basically a road made of rocks and my hand/car shook the whole time.. is that enough to damage suspension of the car?
Old Apr 11, 2009 | 11:32 AM
STCLAIRWEST's Avatar
Im not sure but if you keep that up something will happen.
Old Apr 11, 2009 | 01:47 PM
Calvin's Avatar
Overglorified Altima
It's not the end of the world.
Until you knock an o2 sensor off your bend your midpipe so much that the exhaust can barely squeeze through. But you're not there yet. Just don't make it an ongoing habit and it'll be fine.
Old Apr 11, 2009 | 11:13 PM
2fast's Avatar
how about constantly going on bad roads.. like uneven roads and i feel it a lot cause my car is lowered..
Old Apr 12, 2009 | 01:28 AM
nutt's Avatar
k well my g is as slammed as u can go. going over bad roads is ok and ur gunna feel it more because of how stiff your springs are. for me i scrape everytime i go into my driveway. the problem for me is my hks exhaust were it flexes its kinda shredding. so look at your flex point on ur exhaust other than that u should be chillin. hope this helps
Old Apr 14, 2009 | 01:37 PM
BloodlineG's Avatar
im not lowered but on the front of my g theres the little piece that scrapes under the front bumper? whats that for? i was just going to dremel it off.
Old Apr 14, 2009 | 02:18 PM
Dranom's Avatar
its the diffuser. you can take it out but unbolting the bolts under the bumper
in regards to the OP the flex pipe on the ypipe might get fvck up when scraping so you might get a leak there. So just get a spare just in case
also when you scrape it just hits the metal guards on the side so you wont have a problem there. just dont drive like a maniac over bump and youll be fine.
Old Apr 14, 2009 | 02:21 PM
Hi-TechG35's Avatar
Learn how to drive or or loose your gas tank
mbe32
Nov 13, 2015 11:09 PM
R350k5
Oct 1, 2015 08:41 PM
master111
Sep 25, 2015 08:32 PM
vstring
Sep 21, 2015 11:14 AM
toadfire
Sep 21, 2015 07:15 AM
