question about leaving the g35 undriven
Old Jul 6, 2004 | 02:36 PM
hyunwoo8521's Avatar
I will soon be going off to college and I do not plan on taking my g35 coupe with me. I don't want to give everyone rides or people asking me to drive it so I'll be leaving it sitting in my garage for at least 3 months. If I ask my parents to turn on the engine for me everyday and leave it on for about 5 minutes will that be ok? WHat else would I have to do?
Old Jul 6, 2004 | 03:00 PM
Catatafish's Avatar
Re: question about leaving the g35 undriven
Here's lessons from the aviation world, where we deal with air cooled engines and 50 wt oil. I'm speculating that the same principles apply with an automotive engine.
Within a week the oil is no longer protecting the cylinder walls. That's when the moisture begins to pit or corrode the inside of your engine. The solution is to get your engine at at least 180 degrees and run it for 40 minutes. This gets rid of the H2O in the engine and recoats the metal for another week or two. It has to be hot enough to make vapor out of the moisture and get it to exit through the exhaust. 5 minutes will do more harm than good, effectively scraping corroding metal against one another and not getting rid of all the water.
Ask someone to drive it to the grocery store once a week, or better yet take it out on the highway and run her hot off a few exit ramps. Deposits build in your valves and you need some WOT here and there.
Or, you could take it with you and be assertive enough to fend off the attackers.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats/ Service Engine Soon
Old Jul 6, 2004 | 03:17 PM
Msedanman's Avatar
O.F. Administrator
I've put my vehicles away b4 for extended periods and found that starting once a week or so is good, and letting it run for at least 10 minutes will suffice. Even better would be to drive it a few miles.
Disconnect the battery during idle times to make sure it doesn't go flat.
Make sure the fluid levels are good, gas tank full, and the engine oil is fresh when you put her away. Should be fine.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jul 6, 2004 | 03:54 PM
6mtInCharlotte's Avatar
In the past I have disconnected the battery, and put it up on blocks to save the tires.
Don't know if the blocking is necessary with the low profile tires on the G, but with my Accord, it helped.
Good luck.
Old Jul 6, 2004 | 04:30 PM
kytran40's Avatar
doesnt gas go bad after 30 days?
Old Jul 6, 2004 | 06:19 PM
Msedanman's Avatar
O.F. Administrator
<hr></blockquote>
I read that it does lose some of it's potency, but I've never had any issues with that.
What will happen if you don't fill the tank is water will condense in the tank causing all kinds of problems for you. The way to prevent that is to fill the tank so there's no air space for the condesation to form.
The old gas you have left in the tank isn't prolly the best in the world but once the car is driven again regularly, it soon goes.
You have no choice but to have some gas in the tank anyway-- right? So the best thing to do is to fill it.
You can put a gas and tank treatment in the tank prior to storing to help condition the gas and protect the tank.
C.
Old Jul 7, 2004 | 04:13 AM
ikn3z's Avatar
that's the only reason why you are not driving it? the reason why i can't take it to college is because i can't period. =( im jealous that you get to see it in 3 months though..
Old Jul 7, 2004 | 07:58 AM
Q45tech's Avatar
A good rule of thumb is to never crank a car unless you plan on letting it run till the coolant and oil warms to operating temperature.........10 minutes minimum, 15 minutes at idle in cold weather.
A single cold start [relative at 70F is cold compared to 200F] creates more wear than driving 100 miles at 60 mph after warm up!
All those million mile test never shut the engine off unless changing oil [every 3,000 miles miles every 50 running hours or so]..............10,000 starts [3 x 10 years] is like a MILLION miles.
Change the oil every 3 months whether it drives a mile or not if it runs at idle......Idle is worse than driving 2400 rpms because the fuel is so much richer til it warms up!
Should be jacked up to save the tires taking a permanent set with temperature cycling.
Old Jul 7, 2004 | 10:37 AM
EZZ's Avatar
EZZ
I'd sell the car and get a beater. With the money saved, you could get a nice car when you really need it.
04 Coupe Auto/DG/Prem/Nav/Perf
Old Jul 7, 2004 | 10:54 AM
JaxG's Avatar
Make sure to tell your parents to open the garage door while they leave it running.. lol
2003.5 Sedan / White & Willow / Premium / Navi / Sport / Aero
www.FierceGraphics.com
Old Jul 7, 2004 | 10:07 PM
Max929's Avatar
Here is a good link for you..... everything you need to know about storage.
http://www.dccarcare.com/tipowk/tipowk15.html
'03.5 Silver/Willow Coupe, 6MT, Prem, Nav, Full Aero Kit,
Z-Tube, JWT Pop Charger, Clear Corners
Old Jul 8, 2004 | 02:52 AM
Thanks guys for your help. I'll miss my car while I'm at college. I thought I would go crazy when I couldn't drive it for a week when I went on a trip. But I guess I don't really have a choice. Thanks for your help
Old Jul 8, 2004 | 09:17 AM
GR8TG35's Avatar
Why don' t you let us all know where you live and park your G, then we can each take turns driving your car while your away. You wouldn't have to worry about it idling, we can drive it nice and hard to eliminate any carbon deposits. j/k [img]/w3timages/icons/wink.gif[/img]
I left my old RX7 in my garage while I was away for about 2yrs. other than the plugs fouling, (common in rotary engines at idle), the car was fine......battery needed a recharge once, and a few tanks of fuel to keep it topped off......You should be fine..
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Jul 9, 2004 | 08:37 PM
brittain's Avatar
When I went to Iraq, I left it in a friends garage for 6 months. A neighbor started it about once a week for a few minutes, but other than that I didnt do anything unusual. It was fine and started right up when I got home.
'04 OB 6MT Coupe- Polished Vortech and Crawford Plenum, Kinetix Cats
'04 GSX-R 600
rezendvous420
May 31, 2020 01:26 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
Ninjay16
Jul 20, 2015 01:21 AM
