Check Engine Light on
Old May 30, 2009 | 07:10 PM
infg35coupe's Avatar
i just installed the z tube, k&n filter, spacer and mrev2.....but the check engine light soon is on...any suggestions on what to do to fix it also is it normal that when in neutral it idles at 1000 rpm's
Old May 30, 2009 | 07:38 PM
seymore4's Avatar
m56
hmmm.. I installed all the same parts at the same time on my 2006 6MT a few months ago and never tripped a CEL... Did you reset the ECU? Other than that if there's a dealership nearby take it in and ask. (Just don't tell them it happened after you installed the gear ;p_)
Its still under warranty, and if its because of the mods they'll just tell you that and won't charge you anything. I had a similar issue with my High Flow Cats and a service engine soon light :/
Old May 30, 2009 | 08:10 PM
vash_g35's Avatar
You need to reset the ECU and the throttle body learning procedure. Here's the link
Old May 30, 2009 | 08:38 PM
SwanyJr's Avatar
exactly...need to reset ECU...follow the link in the previous post or leave ur battery cable undone over night....to easy...your ecu with reset and configure itself to your new mods.....
Old May 30, 2009 | 09:51 PM
leaving the battery cable unplugged will reset the ECU?
Old May 30, 2009 | 11:11 PM
reidr96's Avatar
Yep, just remember to crack the windows before you disconnect the negative link. You'll know the ECU has reset when you lose all of your radio presets.
Old May 31, 2009 | 12:51 AM
midnightGcoupe's Avatar
ECU reset should do it, good luck.
Old May 31, 2009 | 03:50 AM
myroncuz's Avatar
not trying to be a dick but i hear so many people saying to leave the battery unplugged overnight..so not nesscessary.. remove negative and pump brakes several times and thats it..
Old May 31, 2009 | 08:29 AM
pwebb's Avatar
pump the brakes?
let it sit. should be ready before lunch break is over. ^_^
Old May 31, 2009 | 11:00 AM
did this and it worked thanks buddy....
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
