grinding sound @ 20-30mph
Old Jun 15, 2009 | 04:20 PM
bina12834's Avatar
whether im coasting or hitting the brakes(more-so when hitting the brakes) i get this loud grinding sound that sounds like when brake pads are worn down.....which is what i would think it was if it happened when i hit the brakes at any time, or if it didnt do it when i was just coasting, but since it does happen when im coasting and it only happens between 20-30mph(really loud at 25mph) i dont think its the brakes.
its funny because braking/coasting is nice and quiet above 30mph and below 20mph
any thoughts anyone?
i have a fully loaded(19" rims/sport suspension) '06 AT btw....never driven a car with larger than 16" wheels or with sport tuned suspension, so i dunno if thats something to be expected when driving with those
Old Jun 16, 2009 | 08:58 AM
bina12834's Avatar
no one?
Old Jun 16, 2009 | 09:36 AM
giddyup69's Avatar
try checking your tires. i had tire feathering on mine... would get a really loud roaring noise when braking to a stop. but u said it only does it between 20-30.. so it doesn't make much sense. maybe it's a bearings issue? are u still under warranty? get it checked out at the dealer.
Old Jun 16, 2009 | 09:38 AM
bina12834's Avatar
i think im still under warranty....bought the car from a private seller, so im not too sure
Old Jun 16, 2009 | 09:58 AM
gary c's Avatar
Grinding noises coming from any vehicle means "Failure" and that's not a good thing. Take you car to the dealership, check on the warranty and get this issue taken care of ASAP! The tire noise mentioned above is a ROAR, not the grinding noise you described.
Gary
Old Jun 16, 2009 | 10:03 AM
bina12834's Avatar
yea...i plan on taking it in this weekend
how can i check on the warranty?
Old Jun 17, 2009 | 06:05 PM
Hunter44's Avatar
possible solution
hey man i had the same problem and still do until i get new tires. Your problem sounds much like mine...around the 20 mile mark it starts grinding...mine was cupping of the front tires.
Old Jun 18, 2009 | 09:54 AM
bina12834's Avatar
i think my tires need to be replaced. im not good at judging tire tread, but it looks low....ill try to grab a pic so you guys can tell me whether or not i need to replace the tires.
bina12834's Avatar
so you got new tires and the grinding sound went away?
whats cupping of the front tires?
Old Oct 21, 2009 | 12:10 AM
superduperG35's Avatar
what did u end up doing? would the dealership fix that for free?
Old Oct 21, 2009 | 08:54 AM
bina12834's Avatar
it was the tires. they were feathered. got new tires and they solved everything.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
