Stinky-G
Old Jul 27, 2004 | 04:11 PM
Mikey35's Avatar
Stinky-G
During the summer I have my A/C on about 80% of the time. When I shut it off and the MODE is on vent it seems to blow stinky air. Anyone else have this problem or know what it might be?
Mikey35
Old Jul 27, 2004 | 05:48 PM
nate1749's Avatar
Re: Stinky-G
Define "stinky."
This DIY may help ...
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Jul 27, 2004 | 06:59 PM
beegoi's Avatar
Re: Stinky-G
I always shut off the a/c but leave the fan blowing a couple of minutes before I shut off the car. Helps a bit by getting rid of some of the moisture, but it still has a bit of smell.
04 G35 Coupe Silver mt6 - stock for now ...
Old Jul 27, 2004 | 07:10 PM
MrCynical's Avatar
Re: Stinky-G
I do the same. And I know theres no way my cabin air filter needs to be changed because it happened from day 1, and it only has like 7500 miles on it.
Especially if I'm going to park in my garage where its cooler, I'll turn the A/C off early. By time I get home, it just starts blowing hotter air and it smells way better next time.
2004 Twilight Blue Coupe
6MT
Premium Package
Aero Package
Old Jul 27, 2004 | 07:21 PM
scottkusf's Avatar
Re: Stinky-G
You live in New Jersey......sorry, jk
2004 6MT Coupe Graphite/Graphite / Performance / Premium / Sirius / Navigation / Clear Bra / Aero / Trunk Mat / Splash
Old Jul 28, 2004 | 11:27 PM
thehunlf's Avatar
Re: Stinky-G
Sometimes, cars get a 'stinky' problem due to water build up inside the air cond ducts due to condensaton. Typical in humid climates. Usually the problem is a plugged drain line, or a low spot that the drain line is not reaching. Your service guys should be able to discuss water accumulation issues, if that is indeed the cause. Again this is my 'guess'. Good luck.
Old Jul 29, 2004 | 02:38 PM
G35COUPEBC's Avatar
Re: Stinky-G
I use to have the same probem.
To avoid this make sure you don't use recycle mode when the AC is on. Mine tends to automatically set to this mode when AC is activated, thus I have to manually turn it off everytime.
5-10mins before turning off your AC, turn off recycle mode to clear any build up.
Hope this helps cause I hated the smell too!
Old Jul 30, 2004 | 12:39 AM
fldrummer's Avatar
Re: Stinky-G
Mine has done this from day one also (it's kind of a musty/mildewy smell), but the only thing the dealer will do is tell me to turn the A/C off and leave the fan on for a few blocks before turning the car off. I suppose it works...in the rare moments where I actually remember to do that! They say all Infinitis are like that; must be a design flaw (?) 'cuz I've never experienced this in any other car I've drove or ridden in, domestic OR import.
2004 6MT (Silver/Willow), premium & aero packages
My old ride (I still miss her; put a lot of pride and joy into it): http://www.n-body.net/registry/john95ga/
Old Jul 30, 2004 | 12:57 AM
GYAL8R's Avatar
Cali Event Coordinator
BASE ACURA TLX NOW WANT A G35 AGAIN THOUGH
Re: Stinky-G
So it's just not my car then...
I'll ask my dealer next week about the "stinky air" see what they can do about it...
thansk for the info man i feel better now
