Which gear do you use to come to a stop
Old Feb 7, 2005 | 10:00 AM
giddyup69's Avatar
Originally Posted by Sukairain
I stay in whichever gear I was in, until engine rev drops below 1500rpm, then I put it in neutral. What's the advantage of putting it in second before neutral?
^^ what he said. i only downshift unless i know i need to get moving again. other than that what's the point? maybe i'm just lazy
Old Feb 7, 2005 | 10:07 AM
clokwork's Avatar
Cmon Son!
not sure about this car, but by braking with the downshifting, you are able to slow down more quickly. you put resistance in more than one place. I downshift when I need to come to more swift stops.
Old Feb 7, 2005 | 10:20 AM
Pratik's Avatar
Moderator
Well if I remember correctly (been driving MT for 9 years but now have an AT Coupe) is that say you're coasting around 40 MPH in 3-4th gear and you're cming to a light, dropping it into 2nd would slow down the car automatically with less brakes. Sure you can throw it into neutral but I think you can conserve your brakes more by downshifting like that.
Old Feb 7, 2005 | 10:22 AM
didit70's Avatar
i don't engine or tranny brake... that's what the brakes are for... and they're cheaper to replace than either the engine or tranny...
Old Feb 7, 2005 | 11:54 AM
Aznteazer's Avatar
i use my brakes too, but it sounds better when u're coming to a stop and u're downshifting....
Old Feb 7, 2005 | 01:56 PM
madchef's Avatar
A little bit on engine braking is ok, as this was taken into account in the engine design. But I would agree that you should be stopping with your brakes, since they are cheaper.
I will typically come to a stop in third, and just pop it into neutral.
Oh, and don't forget, first gear is for starting from a stop, so don't try to downshift into first!
Old Feb 9, 2005 | 01:11 AM
ZeroGen's Avatar
Omega Enthusiast
I use all my gears w/ the exception of 1st to slow down in conjunction with the brakes...
Dallsinghjr1
Sep 17, 2023 11:25 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
