Does ur 6MT Rattle at idle
Old Jul 31, 2004 | 01:55 PM
Diesel1's Avatar
Moderator
Re: Does ur 6MT Rattle at idle
I would bring it in at tell them ASAP, especially if you're close to 12K. Get it checked out, the least that can happen is they tell you its normal, but at least your compliant is on record! SAVE YOUR PAPER WORK!!!
2003 6MT Black Coupe, Premium Pkg. w/ Aero
20% tint all around, Aluminum Pedals
Old Jul 31, 2004 | 05:31 PM
luv2drive's Avatar
20 Year Member
I am with you MrElussive!!!! The noise is noticable but heck if the tranny falls out or the throw out bearing goes... guess what.... they will put in a new one for free...and I am sure by the time all that happens the 05 or 06 or 07 tranny/bearing replacement will have fixed the issues. Mine is a 04 and sounds like that from day one... drives great. All you guys putting in new tranny's and such... well good luck cause my 04.5 does the same thing. Go buy a 45K BMW and such and have other annoying issues. I am sure if we go to their message board they have many issues as well.
Old Jul 31, 2004 | 06:37 PM
neffster's Avatar
No.
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Aug 1, 2004 | 01:36 PM
winw's Avatar
KjbAlto,
I have an 04 6MT, 1150 miles and I have the same clunking sound when I quickly disengage the clutch out of gear. It's a popping sound. So I presume it's just another noise that comes from this car. This is a very noisy car. It's doesn't bother me, I'm just stating my opinion.
Old Aug 1, 2004 | 08:54 PM
Diesel1's Avatar
Moderator
I understand that the tranny's are supposed to make noise. That wasn't my concern, it always had a little bit of noise from day 1. I became concerned when the noise was much louder then it was supposed to be. It's tought to describe without having anyone actually hear how much louder it was over the "normal" noise. In any case, pieces of a defective pressure plate shouldn't be bouncing around in the tranny. Knowing my luck, the car would run fine up until 60K with pices of the pressure plate inside and then the tranny would die at 60,500 miles, when I would have to pay for it!
Old Aug 2, 2004 | 02:22 AM
CKwik's Avatar
Some of you may be describing different noises. But there is a particular rattle to these transmissions that are normal. I've heard the same kind of sounds from 6 speed Supras. They probably have similar designs as they both use a dual mass flywheel. Supra 6 speed trannies have a reputation of being ultra reliable and durable. There are plenty of 800+ HP Supras to prove that.
Thebaws11
Jul 2, 2021 11:36 AM
Blue Dream
Dec 5, 2015 10:56 AM
RWDguy4238
Sep 30, 2015 12:13 AM
vamarris
Sep 26, 2015 12:56 PM
