Transmission replaced by dealer @ 53,000 miles --> what could have caused this??
Old Aug 26, 2009 | 11:38 AM
andychou83's Avatar
Dear all G35 owners,
So my car has about 53,000 miles, still warranted, and it began making this rasping/light rattling noise in between gears during acceleration.. noise comes from engine block... after about 3 weeks of this, i took it to nationwide infiniti in Towson, MD and after 2 hrs of inspection, they said i needed a new transmission... i said sure... can someone explain what could've caused this? Is this because of me? I mean, i took the time to break in my car, ive always used mobile 1 full synthetic every 4000-5000 miles, and the only long trip ive made was from CA to MD once... I did make many 3 hr trips almost once every 2 weeks, and i rarely drive my car hard too.... what couldve caused this and what else does the dealer NEED to replace in lieu of the bad transmission? i was thinking clutch and flywheel... all suggestions welcome..
Old Aug 26, 2009 | 02:40 PM
PublicEnemy's Avatar
auto/6mt?
Old Aug 26, 2009 | 02:52 PM
05G356MT's Avatar
Originally Posted by PublicEnemy
auto/6mt?
Old Aug 26, 2009 | 02:53 PM
LightsOut's Avatar
SIETESG
mine was warrantied out due to bad syncros. I was grinding in 5th gear.
Old Aug 26, 2009 | 04:03 PM
Shakazulu09's Avatar
California to Maryland? That's a hell of a drive.
Old Aug 26, 2009 | 04:11 PM
PTownG's Avatar
who cares as long as they are giving you a new one under warranty?
at 53k I would definetly tell them to replace the clutch and flywheel while they have it apart. They will charge you for the parts but at least it will be minimal or no labor since they have the trans out anyway.
Old Aug 26, 2009 | 04:21 PM
nghiars's Avatar
same here... minewas replaced at ~36K
Old Aug 27, 2009 | 12:17 AM
NgoFrickinWay's Avatar
is the tranny covered under the powertrain warranty?
Old Aug 27, 2009 | 08:40 AM
andychou83's Avatar
Thank you all for the response. Appreciate it.
Old Aug 27, 2009 | 10:37 AM
GboyVA's Avatar
Bad Transmission Causes Clutch Damage
Synchros too for me on my 05 6mt at $30k. Dealer did under warranty but 2 months later clutch slipping. I successfully argued clutch damage was due to synchro issue & was also warrantied. Good luck!
NemesisGee
Aug 11, 2015 07:10 PM
socalg35x
Jul 28, 2015 10:42 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
